Block change
Old Feb 25, 2005 | 04:42 PM
rodman522003's Avatar
rodman522003
1st Gear
Default Block change
I have a fresh 1970 four bolt main 350 short block (flat top piston). Will my worn out '86 iron head L-98 TPI induction, heads, exhaust,etc. successfully transfer over to the older 350 and install in the '86 vette? Vette has 700R4 tranny,Ca. car. Any input appreciated!
Old Feb 25, 2005 | 04:56 PM
cv67's Avatar
cv67
St. Jude Donor '05
Unless your vette has the 2 piece rear main seal it should. Make sure the cam is computer friendly.
Maybe someone else has more to add.
Old Feb 25, 2005 | 05:07 PM
Muffin's Avatar
Muffin
It should be a direct swap. Your ECM/MAF combo is very forgiving. All hard parts are the same.
Old Feb 25, 2005 | 05:14 PM
js292's Avatar
js292
Why would it mater if it had a 1 or 2 piece rear main seal?
To Block change
