scanner question
Old Feb 26, 2005 | 04:28 PM
eboler's Avatar
eboler
Default scanner question
I got a scanner for Christmas but haven't used it yet. Where do you plug it in?
I've used it on my dad's truck, his is above the pedals you remove a panel it plugs right in there.
PS: Sorry if this has been posted before, but I can't seem to find it. If someone knows a thread that answers this question let me know. Also, I drive an 86 manual coupe.
Old Feb 26, 2005 | 05:36 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You plug the scanner's cable into the 12-pin ALDL connector.
The connector is located below the left hush panel to the right of the steering wheel. It may have a plastic cover that needs to be removed before you can access the connector.
Old Feb 26, 2005 | 05:37 PM
eboler's Avatar
eboler
Thanks man, I appreciate it.
To scanner question
