Carpet replacement
Old Feb 26, 2005 | 09:31 PM
Dolfan's Avatar
Dolfan
Default Carpet replacement
Well I'm well into my replacement of the carpet in my '89. The ACC carpet works very well. For those of you that have done this I'm curious what you have used to attach/adhere the carpet without the mass backing to the sill piece on each side? I haven't removed the old carpet yet but it look like it was put on with some type of glue or almost contact cement??????
Any direction from someone that has done this would be great.
Old Feb 26, 2005 | 09:33 PM
Pete K's Avatar
Pete K
3m makes a spray contact adhesive. Spray a light coat on each piece and allow 10 minutes to dry. Spray a second light coat and allow it to dry. Then assemble.
Old Feb 26, 2005 | 11:52 PM
Dolfan's Avatar
Dolfan
I think I have a can of this I picked up from NAPA, I believe it's 3M so I would bet it's the stuff.
Also, how hard is the replacement of the underdash carpet pieces? There was a ton of glue holding those pieces on. I guess the same 3M stuff should do the trick there but as it is hanging it might sag if not done well.
Old Feb 27, 2005 | 11:21 AM
Pete K's Avatar
Pete K
Works like a charm. I am a 20 year floor covering installer and recommend the 3m stuff for most everything carpet related. Works well.
To Carpet replacement
