Shift-up light on
Old Feb 26, 2005 | 09:47 PM
joe3906's Avatar
joe3906
Default Shift-up light on
I posted this problem on the "tech" thread, but no one has come up with a solution yet. I swapped gears, from 2:59 to 3:54 in my 91 Coupe/auto, and at the same time I installed a B & M shifter improver kit, and an Electronic Ratio Adapter (ERA) to correct the speedometer readings. And, now this "shift-up" light comes on when the car reaches a speed of 50 mph and up. Is there some way of turning this light off? The cars an automatic, this light shouldn't be going off at all, right?
Joe B.
Old Feb 27, 2005 | 09:32 AM
joe3906's Avatar
joe3906
No one has had this problem??????????
ttt
Old Feb 27, 2005 | 11:56 AM
rick lambert's Avatar
rick lambert
The up shift light is in all vettes that I'm aware of-wether stick or auto.Myself and another 87 vette owner had the same problem-but at less speed-the up shift light would come on. He thought he cured the problem when he changed fuel pumps, apparently his came back. I replaced my fuel pump and it hasn't been comming on all the time. The upshift light is for two things, 1, it lets you know when you're pressing the RPM level in a certain gear. 2, it's also for fuel economy-both are factory settings-irritating, but I wouldn't worry to much about it.
Old Feb 27, 2005 | 12:00 PM
joe3906's Avatar
joe3906
Thanks for the reply. It only just started coming on after I swapped gears, and added the B & M shifter kit, that't why I found it unusual. Do you think a custom tune could shut it off?
Joe B.
Old Feb 27, 2005 | 12:19 PM
rick lambert
Really don't know if a custom tune would do it Joe, I do know there was another post on this same subject a week or so ago, you might check.It maybe a setting in the computer that now needs to be changed because of the change in gear ratios-but I'm not sure. How old is your fuel pump? My thoughts were-if the pump is getting weak the computer might be reading it as a fuel economy problem-thus causing the up shift light to come on. All I do know-is another member changed his fuel pump and thought his problem was corrected-but wasn't. With me, I changed the pump about six months ago-and it seems to have eliminated my problem with the light coming on.
Old Feb 27, 2005 | 02:11 PM
joe3906's Avatar
joe3906
Thnaks for the insight. Hell, I would venture to think that the fuel pump is original. I think I saw that post about fuel pump changing where one member resolved it. I guess that was you. I'll definately look into the fuel pump theory, is there a way of checking the efficeincy of a fuel pump?
Joe B.
Old Feb 27, 2005 | 04:21 PM
Aidoneus's Avatar
Aidoneus
Default Shift Light after gear change
I also changed gears, but from 3.07 to 3.73 and I experience the exact same thing. If you drive over 50 mph for a few minutes, light comes on and stays on until you slow down below 50. Only did it from the time I changed gears. I also know one other owner with the exact same problem, also only after the gear change. Both of us have had the problem for some time now (2+ years combined) and it doesn't appear to hurt anything. It is annoying as hell though! I also posted this maybe 6 months ago and no one seems to have a solution, but I would say it is definately not the fuel pump since these 3 cases all occurred only after the gear change. I also changed the speedo gears, but it didn't help.
Old Feb 27, 2005 | 04:29 PM
joe3906's Avatar
joe3906
Yeah, that seems to be the consensus of the origin of the problem.
I'm having a custom chip made, and I'm going to see if the problem can be addressed through the chip. If it can, I'll post it.
Joe B.
Old Feb 27, 2005 | 06:56 PM
85 500 horse's Avatar
85 500 horse
Is there a bulb designated that only illuminates the "shift up" notification? If so, maybe removing it can cure this problem. Or is there one bulb that controls many functions, including this and by removing it, will cause the other functions to disappear as well? Just a thought.
Old Feb 27, 2005 | 07:49 PM
88JDO's Avatar
88JDO
Default shift up
I replaced my gears with 3.54's also and I am experiencing the same thing. I'm pretty sure it's because of the computer seeing high rev's at a lower speed.
Old Feb 28, 2005 | 04:11 AM
joe3906's Avatar
joe3906
Jesse sent me an email and explained that this light can be shut down via a tune. I suspected as much, but now I'm relieved. Thanks for all your reples.
Joe B.
Old Feb 28, 2005 | 02:02 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
No up-shift light on my LT4....that I've ever seen.....
Larry
code5coupe
Old Feb 28, 2005 | 05:00 PM
joe3906's Avatar
joe3906
Larry
code5coupe
From what was explained to me, there is a shift-up light on all models. The way to check if you have an automatic is to manually put the car in the low gears and drive; the shift-up light should come on to prompt you to shift-up.
Joe B.
Old Feb 28, 2005 | 05:07 PM
pionexxxx's Avatar
pionexxxx
this is what happens when you go messing with cars. Leave them alone they were designed right the first time around. Start messing with it and it will go downhill from there one thing leads to another just as you have found out. Changing the gears caused the sensor to detect the trans is running at to high of rpms.
Old Feb 28, 2005 | 05:32 PM
TA's Avatar
TA
Say again, except in English this time
Old Feb 28, 2005 | 05:40 PM
pionexxxx's Avatar
pionexxxx
Let me put it in short redneck terms so you can understand, YALL are screwing your cars UP understand that?
Old Feb 28, 2005 | 06:06 PM
joe3906's Avatar
joe3906
I was going to explain why some of us try to improve on a perfect machine, and then I thought: If I have to explain, you'll never understand anyway. So, why bother. LOL!
Joe B.
Old Feb 28, 2005 | 06:39 PM
TA's Avatar
TA
Nope, still not getting it..............can you dumb it down a bit more for me
Old Mar 3, 2005 | 02:28 AM
PierEagle's Avatar
PierEagle
I posted the same question in the "Tech" section a few days ago. I have an"87 Hbk, L98 w/auto trans and all stock. When cruising at 55 or above, the upshift light comes on. If I hard accelerate or slowdown to about 40, it goes off. No codes are thrown. The trans shifts at all correct points and the torque converter clutch kicks in and out at the proper times. You might want to look at some of the answers I got in Tech Section titled "Upshift Light on C4".
To Shift-up light on
