Sticky Headlight
Old Mar 3, 2005 | 09:33 AM
Hank Bullwinkel's Avatar
Hank Bullwinkel
4th Gear
Default Sticky Headlight
In the interest of helping you save a few bucks, I want to tell you about a recent headlight fix I used. The left light seemed to be physically blocked, but there was no visible blockage. I could see space around the entire rotating unit. The motors on both sides whirred strongly, but my left light would open only if I disembarked and whacked the housing smartly with my fist. Inconvenient. As i fiddled with it, I loosened the screws that held the motor and the outside mount and observed a slight improvement. Further fiddling showed that a shim under the outer housing would eliminate the problem. This was a lot easier than a similar fix on my '65 C2. If this info saves you time or money, then we've both won.
Hank
