Leaning on Vettes!
Old Mar 12, 2005 | 03:43 PM
Z51JEFF's Avatar
Z51JEFF
Originally Posted by 93JetJocky
I can put pressure with my fingers on the inside and pushing back close to flush (the two sides of the crack). Thank goodness for flex in paint.
.........You lost me here chief,you cracked the fiberglass completly in two but didnt phase the paint?
Old Mar 12, 2005 | 04:09 PM
19corvette91's Avatar
19corvette91
last summer me and my buddy stopped at a wawa on the way from sleazeside to the titty bar..........we come out with our snacks and sodas and he sits on the fender/hood.........i dont think he ever heard me scream louder in my life........luckily no damage resulted
Old Mar 12, 2005 | 04:33 PM
VQT88Vette's Avatar
VQT88Vette
Originally Posted by steve9899
Either you weigh a heck of a lot, i.e. too big to fit into a vette, or there was previous damage. Maybe the previous damage didn't go all the way through and you finished it off.
I lean on mine all the time and had no problem. Beside the shopping cart made a crack there by some idiot . The cart had to be pushed very hard and rolling down on an incline to made the crack on my IMO.
Old Mar 12, 2005 | 04:40 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
Im gonna go with the previous damage story too....Ive leaned, sat, and boinked on several vettes...no damage
Old Mar 12, 2005 | 05:15 PM
mitymek's Avatar
mitymek
the inside of my fender doesnt look like that at all.yours appears to have the gs flares added?
Old Mar 12, 2005 | 05:32 PM
CMYC4GO's Avatar
CMYC4GO
I lean on mine all the time, and weigh upwards of 250. Believe me, you didn't do that by leaning on it. That crack had already started, probably internally, and you just finished the job. Either way, it sucks. Looks like a pretty car!
Old Mar 12, 2005 | 05:46 PM
TOO_HOTTVETTE's Avatar
TOO_HOTTVETTE
Trust me I have had this vette for almost 4 years, I know every mm of it. I heard the noise when I leaned back against it. I sort of flopped backwards not just gently leaning. The only thing holding it intact is the paint, you can see it flex when I press on it.
This fracture was not there. I did this leaning against it.
Are you the original owner? If not, it may have had that rear quarter replaced with an inferior aftermarket panel. That said, I have to check to see if mine is as fragile in that spot as you say. I'm sure when you fix it it will be better than new. Good luck.
Old Mar 12, 2005 | 06:20 PM
91DRM's Avatar
91DRM
From: Isle of View "Mofo skated me, that was my up!"
Sorry for your problem. Not to be contrary but something is not right.
Old Mar 12, 2005 | 09:50 PM
Jet-Jock's Avatar
Jet-Jock
Yeah I've read through info in the service manual and found lots of good info on SMC repairing from net searches. Came across some interesting reading too about semi-rigid materials. I'm going to pick up the materials at the local paint supplier 3M distributor. It will take an over size patch and some special adhesives, then a finish coat of a special filler material. It only cracked the paint on the edge I think if I can get it taken care of in the next few days it should be fixable.
Seriously I've cleaned with the wheel off several times in there and wipe the under side lip every time I wash/dry it. I would have noticed any previous damage. No this is strictly stock. I think it was just the right force in the right place at the wrong time.
Old Mar 12, 2005 | 10:51 PM
cv67's Avatar
cv67
St. Jude Donor '05
Boy, that's Charlie Brown luck for sure...Kind of like loosing it, chucking a socket on the ground, only to have it bounce back and chip the paint... Hope the damage isn't too $$ bad
Old Mar 13, 2005 | 12:55 AM
VetteUSA's Avatar
VetteUSA
St. Jude Donor '07
Sounds like just an unfortunate freakish cracking incident. My best guess would be that for whatever reason it had already been somewhat weak, then you happened to put right pressure at just the right point to make it crack.
The good thing is - is that it can be repaired.
Old Mar 13, 2005 | 01:24 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Seems the best way to see if it was previous damage or not is to plop your butt against the other side.
I'll have be more careful around that stuff.
Old Mar 13, 2005 | 09:56 AM
  #33
Jet-Jock's Avatar
Jet-Jock
LOL no I don't think I'll try that. I appreciate the thought though.
Old Mar 13, 2005 | 12:35 PM
  #34
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Painfull....
Old Mar 13, 2005 | 01:00 PM
  #35
91DRM's Avatar
91DRM
Default Survey Says!
Great Idea! Perfect opportunity for a survey. Everyone, go out to your garage, do a butt plant on your fender, report back. Cracked [the fender smart azz] or not cracked. Will do a tech article for the forum.
Old Mar 13, 2005 | 01:57 PM
  #36
smack123's Avatar
smack123
Originally Posted by 87Clwy
As you can see, you can barely see my car in the back ground, but I got a nice shot of all 4 girls
Huh? What car?
Old Mar 13, 2005 | 02:38 PM
  #37
Kanmer's Avatar
Kanmer
Cruise-In VI Veteran
I'll take the one on the right with a side order of fries please. And a Samuel Adams.
Bob
To Leaning on Vettes!
Old Mar 13, 2005 | 04:58 PM
  #38
corvette1989bham's Avatar
corvette1989bham
If you wash your car / wheels / suspension with cleaners like Deep
Purple / or other strong degreasers it will make all your fiberglass brittle and weak, it will also cause your leaf spring to crack in two just by sitting still...maybe if you have used thses types of cleaners that might explain the weak fiberglass / urethane, never use anything (my recomendation is ONLY simple green - opinion may vary) on your car.
Old Mar 13, 2005 | 05:08 PM
  #39
Jet-Jock's Avatar
Jet-Jock
I'm with you Simple Green only. Actually while talking to my daughter on the fone, I was on the garage and lean against the wheel lip on the other side. It flexes a lot more than I'd prefer and with a little more force I can see how it happened.
My recommendations, just don't let anyone lean on those rear fender lip flairs.
Old Mar 13, 2005 | 05:39 PM
  #40
bdvdvh7's Avatar
bdvdvh7
regardless, i am going to make an effort to not do it... i think we just do it without thinking...reflex action. just don't want to take any chances... thanks for the scoop.
