Ignition lock stuck...
I was able to move it backwards into accesory mode a couple times, but even that was kind of hard. I tried moving the steering wheel left and right, and I tried moving the tilt up and down, all while moving the key. I even tried another key without success. The steering wheel is locked, so I just moved it back and forth the little it would move.So, I guess I'm going to have to tear apart the steering column, unless someone can give me any other ideas.
How hard is it to tear apart the steering column in these cars? Can I get to the ignition switch by taking off the steering wheel, or do I have to remove the column from the car?
At least this happened in my own driveway and not at work or somewhere else. I had driven the car the night before and had no problem. I drive the car almost everyday, and I think I noticed a little difficulty with turning the key occasionally, but nothing all that bad. I guess something just broke.
Anybody else have this happen? By the way, my vette is an '89 with the 6-speed manual transmission.
Good luck
Remove steering wheel
Remove telescoping lock mechanism
then you when you pull the steering wheel you will need a adapter that goes on the front of your wheel puller to lock the telescoping mechanism in place (you can saw off a nail and put it on front of your puller). After all that is off, there is a plastic bezel that cover the cruise and ignition plates, remove that THEN you can remove the old ignition..tie a wire around the old wire before you pull it out to make sure you can get the new wiring in. I HOPE you know what your Vats resistance is or have an extra key.
BTW be SURE to mark the position of the wheel and retainer before you take them off to prevent your steering wheel from being off center.
Good luck
Once you get it working, keep it well lubed with graphite, although in the back of your mind know the ignition lock is breathing its last...
You will need a steering wheel puller, naturally. You will also need to stop by your local GM dealer parts counter and pick up what they call a "turtle". It was about $10. Don't bother trying to save your old one, it will break into several peices when you pull it off.
Just pay attention to how everything comes apart. I laid everything out in order of disassembly on a rag on my dash(This was before I had my service manual).
A little preventative maintainence for everyone. I have read that having a bunch of keys or other crap on your keyring puts undue pressure on the ignition switch and will cause it to wear unevenly and over the years cause this problem. I have the two Vette keys only on that ring. Better safe than sorry.
Art
This may work as a last resort if none of the other suggestions get it.
Thanks for all the great suggestions, I will let everyone known how things turn out.
Thanks to all for your help!!!
