LED replacements for 3rd brake light bar?
Old Mar 15, 2005 | 02:15 PM
flaagan's Avatar
flaagan
CF "Young" Senior Member
St. Jude Donor '12
Default LED replacements for 3rd brake light bar?
One of the four lights in my 3rd brake light bar on my '86 is out, and it appears to be the bar itself no longer works on that plug. One of the other plugs is starting to burn bulbs every couple of months, while the other two seem to work fine.
I'll be at a parts yard in the next week or two, so I'll try to find a replacement bar then, but has anyone seen LED bars for sale? would save me a few buckaroos in the long haul and would probably serve make that 'safety light' more useful.
thanks as always, guys
Old Mar 15, 2005 | 03:03 PM
CREWZIN's Avatar
CREWZIN
I add a CHMSL bar to my PT Cruiser rear wing. Don't know if it will help you or not but here's the web site.
http://www.hamsar.com/chmsl.htm
Try putting CHMSL (Center High Mounted Stop Lite) in a search engine and you'll see loads of places that sell and make them.
Old Apr 19, 2005 | 02:31 AM
flaagan's Avatar
flaagan
St. Jude Donor '12
Figured I'd bump this back into the spotlight for a short bit..
How hard (what materials) would be needed to solder together a board with a row of *bright* LED's that could be used to replace the brake light bar.
Biggest problem I could see would be whether the power coming for the light bar currently would fry the LED's if it came in directly.
I won't do this myself just yet, but if another one of the light sockets on my light bar goes perma-dead, I'm probably going to want to do this.
Old Apr 19, 2005 | 09:13 AM
ynk1121's Avatar
ynk1121
I would imagine to make one would be straightforward. 12vs would definitely kill them. I think the max a led can handle is 2.5 - 3v. It has been a while since my last electronics class but there is a formula to figure out what resistor you will need to drop the 12v to 2.5v. A five pack of resistors at radio shack is 99 cents and 1.99 for a led. I don’t know how much a whole light bar goes for but depending on how many leds you want to put in, it will probably cost more to make one then buy one.
Old Apr 19, 2005 | 11:04 PM
jfb's Avatar
jfb
You can replace the incandescent lamps in the third brake light with red superbright LED's. Each LED requires a 600 ohm 1 watt resistor in series with the LED to the two wires that go to the incandescent lamps. Proper polarity is required to make the LED's light. Reverse polarity won't hurt the LED's. Radio Shack doesn't sell 1 watt resistors any longer, but two 1200 ohm 1/2 watt resistors in parallel equal a 600 ohm 1 watt resistor. You can mount the LED's on a piece of perf board also available from Radio Shack, 1/2 x 11 inches. The perf board will slide in front of the lens and two pieces of double sided adhesive foam on each end of the perf board will hold the perf board in place. If you want to replace the lamps (they are expensive) and can't find the superbright red LED's, I have some and can mail them for $1 each, you need 4.
Old Apr 19, 2005 | 11:25 PM
the oz's Avatar
the oz
Wow, that post hurt my head
Simple question, and this isn't worth a new thread, how does one get to these bulbs (I assume it is open the rear hatch and undo those two hex bolts?)
What sort of bulb do I need to get? I don't want to open it up once to get the bulb out, then put it back, go get the bul and reopen it agian to replace....
Old Apr 20, 2005 | 12:39 AM
jfb's Avatar
jfb
Two bolts takes the third brake light assembly off the car, then three I think more screws takes the assembly apart to gain access to the lamps which are #881. When you find out their cost, you too will want to install red LED's which will last longer than you will.
Old Apr 20, 2005 | 01:22 AM
flaagan's Avatar
flaagan
St. Jude Donor '12
I was able to get replacement lamps at Napa Auto Parts... but the price combined with finding out one of the four lamp connections doesn't work at all is what originally brought out this thread.
As far as mounting the setup, i would imagine you could take advantage of the mounting screws to hold it in place.. probably could do the whole setup on a piece of 'junk pile' plastic from Tap or some other sturdy material that can handle drilling and mounting.
Old Apr 20, 2005 | 08:41 AM
-=Jeff=-'s Avatar
-=Jeff=-
What Size LED are you using the typical size found at Radio Shack or the Jumbo LEDs?
Old Apr 20, 2005 | 03:10 PM
azzkikr's Avatar
azzkikr
I had this idea for awhile - here's what I did... I bought a L.E.D. third brake light (d.o.t. compliant) from e-bay. Then I simply removed the "guts" from my factory light, I also had to take a "dremmel" and permenantly modify the inside of the plastic inside the factory housing. It nearly worked perfectly. I'm still looking for something a little better or maybe even replace the entire 3rd brake light all together with something else. I'm going to check on the links the other forum members listed...
Old Apr 20, 2005 | 03:15 PM
azzkikr's Avatar
azzkikr
Don't let pride get in your way from asking the "parts guy" at the store what bulb you need, and usually they are still listed in the books hanging from the shelf in the isle where you get the bulbs.
Once you remove the two hex bolts, lift up the unit and underneath - I think there are two more screws - when you remove the last two screws the top, bottom and lense come apart.
Years ago, I had to pay between $8 - $10 for each bulb, now I think they are under $2 each
Old Apr 20, 2005 | 03:43 PM
86_RedRider's Avatar
86_RedRider
Cruise-In V Veteran
St. Jude Contributor '03 & '05
i thought someone on here took a strip out of their blazer and put it in their corvette. not sure if it is LED, but it worked. you could probably find one at a parts yard.
Old Apr 20, 2005 | 09:35 PM
jfb's Avatar
jfb
Jeff, I bought some T1 3/4 7000 mcd red LED's from Unitech Systems. They only sell in quantities of 35. You can buy similar superbright red LED's from www.hosfelt.com in small quantities. I still have most of the LED's I bought and will sell them for $1 each.
Old Apr 20, 2005 | 11:07 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I was just looking at the TLSH180P on the above site at $0.79 each. It has 8,000 mcd and will drop 2Vdc at 20mA.
Assuming the electrical system puts out no more than 15Vdc, you could use a 1/4 W 800 (P=V**2/R=13**2/800=0.21W) Ohm resistor in series with each LED and have close to max illumination with inexpensive parts.
Since I now have two bulbs out maybe this requires a trip to Radio Shack. Thanks for the leads.
To LED replacements for 3rd brake light bar?
