battery ground
Old Mar 21, 2005 | 10:09 AM
Randy93's Avatar
Randy93
St. Jude Donor '06
Default battery ground
Never heard of this before, but the screw for the ground is stripped!
Anybody ever try to cut off the end and replace with a new one?
Or would it be best to just replace the whole cable?
Old Mar 21, 2005 | 10:28 AM
redwing76's Avatar
redwing76
Which end?
Old Mar 22, 2005 | 10:43 AM
Randy93's Avatar
Randy93
St. Jude Donor '06
the screw going into the battery
Old Mar 22, 2005 | 11:35 AM
Jet-Jock's Avatar
Jet-Jock
That screw will pop out of the end of the cable. You can get replacement screws at local parts stores like Autozone. When you tighten it up it will reseat. I replaced mine when it froze into my old battery then just broke off taking the lead section of the battery with it.
Old Mar 22, 2005 | 12:50 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Thanks Jet!
Old Mar 22, 2005 | 12:56 PM
c4cruiser's Avatar
c4cruiser
What do the threads in the battery look like? The battery female threads are typically lead and the post in the cable is steel. You might try a thread chaser in the battery terminal to make sure the threads are clear.
Old Mar 22, 2005 | 01:29 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
It is a brand new battery and you can see the threads are worn on the screw.
To battery ground
