Garage Ground Breaking
2X6 construction is overkill just for more insulation (IMHO).
Make your ceiling height at least 12' 6" on one side for a future lift.
On the non 12' side make a storage loft.
Dig out the floor so you have cement piers on the 12' side to help hold a lift. (I dug 6 so I could go 2 or 4 post lift, went with a 2 post)
Run three 1 1/2" conduits into the house.
One for electric service
One for phone, cable, network, security
One just for spare
Run 2 1/2" CPVC lines for water, one to use and one for a spare.
Run a gas line if you have gas.
Don't heat with a portable, install a gas (use propane if no gas) hot air heater. It will warm up the garage fast. I installed one, the heater cost about $400 and I spent another $600 for ducts and misc. Install a programmable thermostat. Set it up for 4 times a day at 45 degress. That way when you turn up the heat you don't have to remember to turn it down! Plus with a forced air system A/C can be added in the future.
Install a camera on the outside of the garage, connect it to a video input on you TV inside the garage so you can see who's coming in the winter when the doors are closed. You can also split the camera signal and connect it to a TV inside the house, run an extra coax for this.
If you have a home computer network run a CAT5, even if you don't run it.
Run several multi conductors in conduit #2 for phone and security.
Run some speaker wires.
Plan your lighting and install ceiling outlets so if a light fixture goes bad it's easy to replace. Set up your lighting so it's on 2 or 3 switches.
Plan your electric and don't skimp on outlets. Think about one of those multi outlets that are on a retractable cord and plan to install between the doors. It great for when you need an extention cord inside or outside.
If you plan you need 6 breakers, buy a 12 slot panel.
I used X10 switches for the exterior lights and bought an X10 controller for the house. That way I could set them up on a timer and control them from the house. (I have other X10 devices in the house)
I had ran a 3/4 PVC line from my shed down in the concrete into the garage for air. Don't do that, being in the ground the line accumulated moisture and PVC although rated well above the PSI can be unsafe due to oils, fitting glue break down. Plus air lines should be run high with a drop past the air hose connections with a drain valve. I just redid mine in 1/2" copper and ran it high with the drops and valves.
Set up the air so the compressor is in a shed outside the garage, run a conduit (in the cement) for the electric. Use a big enough conduit for a separate compressor circuit and a separate shed lighting/outlet circuit.
Plan for a shed. You can buy a 8X10 Sears metal one for cheap. Plan so when the garage floor is poured they pour a pad for the shed. A shed is great to keep all the lawn and garden stuff out of the garage!
I used drywall on the walls. I installed 5/4 PT decking as a baseboard before the drywall then installed the drywall on top of that. The bottom edge of the drywall (resting on top the 5/4) got a plastic J channel on it.
Have the contractor put in a moisture barrier below the floor.
DO NOT use UCoatIT, the product sucks and so does their support. Rustoluem has a nice industrial product. Not the HDepot line, you have to go to MAB to get this.
That about all I can think of right now, here's a link to some of my pictures: http://www.garagejunkies.net/showthread.php?t=177
Here's a site you need to have a good look at: http://www.garagejunkies.net/index.php?
For lighting when the time comes...you might want to look in to newer, more efficient fluroescents. The warehouse I go to for ac delco and motorcraft parts recently had more efficient fluro's installed and God in the heavens they're bright. One bulb is as powerful as five mercury vapor lights. I took the name of the electric company who installed them...so let me know if you want to look in to that.
How's everything else? Car ripped apart(mods) or is it intact.
Car show season will soon be upon us...and with any luck, I'll have a 'vette[C5-coupe] again soon.
Take care.
One just for spare
As far as the giprock, I used 1/2" plywood. Would not do it anyother way. A little expensive, but you can put whatever you want where ever you want.
Fred
One just for spare
Hey Jay, Hey John,
The fleet is up and running. I did have the rear end out of the car for a new clutch pack and poly bushings. It's back together now and running fine. I had to leave the 'vette out in the snoe last week while I did the breaks on the truck. The truck is done now too.
Two 'vette........two covers..................Hmmmmmmmmmmmm
