dash lights out
Old Mar 24, 2005 | 06:04 PM
88JDO's Avatar
88JDO
Default dash lights out
Recently decided to start driving the Vette more. Put a battery charger on it Monday night for about an hour. Started right up. Took it back and forth to work Tue. and Weds. with no problems. Drove to work today and ran over a pigeon. (slowed down and tried to avoid hitting it, thump thump) Got in to leave work and started the car and both turn signal indicators were bright green and high beam indicator was bright blue. Dash lights didn't come on but I could barely make out rpm's and mph. Got home and verified turn signals worked ok. Checked all the fuses next to the dash on the passenger side and they all apeared good. Anyone have any ideas?
Old Mar 24, 2005 | 07:53 PM
Chewch87's Avatar
Chewch87
Something definately became disconnected somehow. I have a bad leftside turn signal lamp socket....every once & a while the inside turn signal will go on bright green..then I know the turn signal is out..I then open my hood and press on the socket..the bulb goes on and thats that. Hopefully some connection came loose.
I had a bad short over the summer last year....somehow after a wash...my rear taillamps, interior twilight sentinal , A/C control panel and Shift console lights went out. Everything else was ok.Weird. I ended up taking it to an Automotive Electrical specialist. Cost me $175 for the diagnosis/labor and parts . Turns out I had a short in the rear tailight harness. You may have to have a specialist look her over . Good Luck
Old Mar 24, 2005 | 08:19 PM
LangstC4's Avatar
LangstC4
http://www.batee.com/corvette/dcrg/problems.shtml
Sounds like a possible ground problem...here is a helpful link.
Old Mar 24, 2005 | 09:34 PM
88JDO's Avatar
88JDO
Thanks for the link. Lots of interesting reading. I'll probably look at this Saturday. Hopefully it's the ground. I did notice the dash lights flickering on my drive to work in the morning.
Old Mar 25, 2005 | 02:35 AM
yellowlust's Avatar
yellowlust
I found this forum because of the exact small issue. There is a ton of info. It wasn't until I pulled the dash (for the 14th time) and soldered the ground up as described in the above link did I never have a problem again. Do it right the first time.
Old Mar 25, 2005 | 06:16 AM
TaylorMutts's Avatar
TaylorMutts
Only 14 times? I know the feeling--I think I was in denial that I would need as much work on my '84 dash. I was looking for the quick fix. Once I took my time and used the repair procedure noted above, all was well!
Concerning the ground, I did not have much luck grounding the ambient temp sensor to the door frame area. I ended up running a ground wire through the firewall and tapping it in to the frame. That too kcare of the ground issue, but then I also had to resolder key points on the circuit board.
Follow those instructions posted above and you should be fine.
Old Mar 25, 2005 | 06:47 AM
HamCrab87's Avatar
HamCrab87
Ironically it COULD have been the pigeon . On my 87 when I hit bumps in the road (like the seam between concrete segments) my dash lights will go out sometimes and I get the turn signal/hi beam lights only. First time it happened was on a cold December night coming through the mixing bowl in Springfield VA (for the unfamiliar .... mixing bowl is the huge interchange where I95, 395, 495, and a whole lotta other roads all merge into one spot). Not a good time for troubleshooting .... I had my foot to the floor and was busy slalom driving around all the obstacles as I merged. Drove down 95 to 295, then to Route 10 in chester (about a 90 min drive or so) with no lights .... just wondering what the heck happened. On Rt 10 I hit a bump in the road and the display worked fine. Problem was dormant for several weeks then reappeared on the way to work. I tapped the display housing with the side of my hand (gently!!!) and display came back to life. My problem is most likely a cracked solder joint in the display assembly .... problem has reoccured a few times since but a tap at the right turn signal lamp area restores operability. One of my summertime projects is to pull the cluster and correct the situation.
To dash lights out
