HELP! My "hi center" brake lights works fine, but the main brake lights aren't functioning. The tail lights themselves work OK, but don't do anything when the brake is applied. Any idea how to fix?
I checked the fuses and everything seems OK there. As for the pedal switch, would that explain why the center light works and the other one's dont? How do I check this?
Thanks!
The pedal switch has two sets of contacts inside. One for the high center brake light and the other controls the lower brake lights. I had the opposite problem --------- lower lights but no high light. I removed the pedal switch, took it apart and cleaned the contacts, and it fixed the problem.
On mine, I replaced the 7 dollar switch, problem fixed
Whew...that's good news! I just purchased it and was afraid of a crazy bill from the dealer! Since I'm new at this whole world, I wouldn't know the pedal switch if it bit me! Any chance that someone has a picture of it?
