Yet another corvette temp question..:)
At what temperature should I start getting worried, and what temperature is considered ideal?
Thanks...
Richie
The fans are electric, so your gas mileage shouldn't be affected. Damage to the car...I wouldn't think so, except it might burn the fan motor out before its time and it will take a little more time for the engine to warm up.
I wouldn't start to worry unless you see temps above the 230 range.
Why did he recommend doing this? Did the fan turn on at all? The fan is operated by the ECM by grounding a relay. When the coolant temp sensor sends a certain value to the ECM, the ECM grounds the fan relay and the fan should start. Does your car have the Z51 or Z52 suspension package? If so it should also have a secondary fan in front of the A/C condensor and is easily visible from behind the front plate under the car.
C4's are "bottom breathers" and you can get a tremendous amount of dirt and debris sucked up into the A/C condensor and radiator thus blocking airflow through them. Keep this area clean by directing a stream of water from the back side of the radiator to flush the garbage out of the air passages.
Routine maintenance of the cooling system is important. You should do a cooling flush every few years and replace with a 50-50 mix of a good ethlyene glycol (green) coolant and distilled water. Keep an eye on the radiator hoses and replace any hose that spots that feel soft. A new thermostat of the correct temp is also a good thing to do at the time of coolant flushing.
Typical temps for a cooling system in good shape should be around 190 -210 at operating temperatures and when the temp hits 225-230, the fan should kick on and lower the temps backdown.
