Help!! - Nash 4 + 3 - No Reverse
Old Apr 2, 2005 | 02:46 PM
85_TPI's Avatar
85_TPI
Default Help!! - Nash 4 + 3 - No Reverse
Would like to get a quick input on why I have a manual Nash 4 + 3 - 4 Speed transmission and now my reverse gear is "slipping" real bad, almost to the point of not pulling at all.
This is an '85 with original transmission.
I thought with a manual transmission, it either pulled or it didn't. I have always associated slipping, with an automatic transmission.
Please help...
85_TPI
Old Apr 2, 2005 | 04:08 PM
86C4EVER's Avatar
86C4EVER
It could be the clutch, but if that is alright, must be the direct on the OD. I am not sure how the OD works on the reverse, but I assume it is in direct mode.
I guess that is kind of stating the obvious, hopefully someone else will jump in with more info.
Old Apr 2, 2005 | 04:49 PM
85_TPI's Avatar
85_TPI
Yea, first thing that comes to mind IS the clutch but it seems to do fine in the forward gears.
That OD has, as I understand it, been the source of issues with this tranmission, since it's inception. Someone else stated that Doug Nash lost the house from trying to warranty the box!?!
Does anyone know if there's a place in the archives where the Nash Overdrive is discussed?
thanks much,
85_TPI
Old Apr 2, 2005 | 05:44 PM
flannel_man's Avatar
flannel_man
Cruise-In VI Veteran
Check the ATF fluid in the OD unit, sometimes when it is low it will slip in reverse. happened to mine when I changed the radiator out and had to replace the amount that was in the raidiator. Hope it goes well for ya
Old Apr 2, 2005 | 05:46 PM
Carl Johansson's Avatar
Carl Johansson
Default OD toast!
After my OD quit working my reverse followed suit - I said to heck with it and got rid of that abomination.
Old Apr 2, 2005 | 06:57 PM
85_TPI's Avatar
85_TPI
I got the car up in the air and pulled the plug from the trans & OD units.
- The OD unit leaked black/grayish looking oil out, all over my Georgia Bulldogs Sweatshirt!!!
- The trans unit was low on the gear dope. I couldn't even reach any with the tip of my small finger.
I removed the radiator a few months back and had it worked but I never even checked the ATF for the OD unit until now.
Could I have caused damage??
But it still surprised me to not find the gear dope in the manual box.
That's easily fixed but wouldn't think that would be a cause of my reverse gear slippage problem but I could be wrong here too.
I checked out the DougNash 4+3 OD section at the http://www.5speeds.com/dne.htm website and they did some pretty good talking on how/what/why you want to keep the 4+3 and just fix the problematic issues with it.
Makes meBrain think somewhat...
Thanks for any further assistance/input on this.
85_TPI
Old Apr 2, 2005 | 07:05 PM
lead foot 85 vet's Avatar
lead foot 85 vet
sorry to inform you but your overdrive is toast.......losing reverse is common..........any trans shop can rebuild it but parts can be a pain. good luck
Old Apr 3, 2005 | 01:53 PM
steveb's Avatar
steveb
www.pipersauto.com/4speeds.html
Old Apr 4, 2005 | 09:41 AM
85_TPI's Avatar
85_TPI
Thank you, gentlemen, for your help with this.
I'm now making efforts to contact someone about rebuild information/costs...
85_TPI
Old Apr 4, 2005 | 12:37 PM
redwing76's Avatar
redwing76
So how come no-one replaces the DNE with a 5speed out of a IROC?
Near as I can tell to rebuild a DNE is about $2,500.
The DNE got better with age.
Old Apr 4, 2005 | 12:42 PM
eboler's Avatar
eboler
As soon as mine goes out I'm getting a 5 speed.
Old Apr 4, 2005 | 01:14 PM
88BlackZ-51's Avatar
88BlackZ-51
Please help...
85_TPI
i had that same problem and it was my clutch, i changed to a centerforce clutch. I also had problems in forward gears.
Old Apr 4, 2005 | 03:11 PM
tjm2070's Avatar
tjm2070
the 5 speed from the camaro to the best of my knowlege was never put behind a 350 (and therefore iroc as well i believe because all irocs were 350's right?). the 5-speed couldnt support the torque of the 350 and i guess wasn't much stronger than even the 305 put out.... so they often had problems...
tj
Old Apr 4, 2005 | 06:58 PM
ductape's Avatar
ductape
Cruise-In V Veteran
Go find Scorp in the C4 Tech/Performance section. He knows these puppies inside and out. If you do a search in that section on 4+3 stuff, you'll get a bunch. The reverse slipping is a sign of the OD going out, however, throw some fluid in it, and see what happens. I bought a suction gun from NAPA to put fluid in mine. Slickest way I've found. In the event of replacement, other years will fit. I have an '88 OD in mine. Works like a charm. Doesn't use the cable on the TB. I do believe a 6 speed will jump right in there, if you're lookin' for a change. The best to ya
Old Apr 5, 2005 | 12:54 AM
Insane1's Avatar
Insane1
tj
My '88 IROC convertable came with a 305 and a 700r4
Old Nov 9, 2021 | 12:26 PM
Kane The mane's Avatar
Kane The mane
2nd Gear
Before you fixed the clutch did it move slowly with high rpms going foward and vibrate when going backwards if it went backwards?
Old Nov 9, 2021 | 10:40 PM
jv9999's Avatar
jv9999
The OD fluid should be red ATF. Since you're also low on gear oil, I suspect the seal between the trans and OD may be leaking gear oil into the OD. '85 was not a good year for the 4+3, especially if not well maintained.
To Help!! - Nash 4 + 3 - No Reverse
Old Nov 10, 2021 | 08:44 AM
arbee's Avatar
arbee
I'm going to go out on a limb here and guess that after 16 1/2 years, the OP has had some kind of closure with his problem.
Old Nov 13, 2021 | 07:20 AM
flannel_man
Hope your pockets are deep. When my OD went out in '02 it cost $3k to overhaul it and do clutch, no telling what it would be now.
Old Nov 13, 2021 | 09:48 AM
arbee's Avatar
arbee
Seriously? Reading and comprehending the written word is a lost talent on many.
