Lug Nut Key Question-Help!!
Old Apr 8, 2005 | 11:33 AM
Frank43's Avatar
Frank43
Default Lug Nut Key Question-Help!!
Hey all,
Getting ready to do some brake work, and I LOST my lug nut "Key" for the one lug nut lock! Damn! I have a 1996 with stock SawBlade rims.
Question is, IS this a universal key that I can buy, or are they all different??
If it is universal, where can I get one? Madvet.com?
IF NOT, what do I do now to get my wheels off??
Help,
Frank
Old Apr 8, 2005 | 11:54 AM
Zproud's Avatar
Zproud
I have used a socket you take a 5 lb hammer and beat it on...and use an inpact gun... Snap on has a tool ...you could go to a tire store...they should Have the tool ...and could remove them for you
good luck
Old Apr 8, 2005 | 12:16 PM
rws.1's Avatar
rws.1
Buy a Sears Craftsman socket (lifetime guarantee including abuse), one size smaller than the lug nut.
Use the hammer as per Zproud's post to beat it on, remove the lugnut. Use a rod to drive the lugnut out of the socket... return the damaged socket to Sears for a replacement
Old Apr 8, 2005 | 01:09 PM
SilverBeast's Avatar
SilverBeast
St. Jude Donor '05
The car came with a packet for the keyed socket along with the Owner's manual. Mine was still in it when I bought it. There's a key number and address/phone number in the packet to get the thing replaced. Otherwise - I agree with the others - pound a socket on and remove that way. (but I wouldn't take it back to Sears).
Old Apr 8, 2005 | 01:15 PM
GSjimbo's Avatar
GSjimbo
I read in a similar thread that if you over torque the other luga the lock will be loose enough to turn off easily. Other than that, the other recommendations above work well too.
Old Apr 8, 2005 | 01:36 PM
LT1SPUD's Avatar
LT1SPUD
....or maybe a small packet of plastique and primer cord.......
Old Apr 8, 2005 | 02:06 PM
dndrsn's Avatar
dndrsn
Do you mean a little C4 for the C4?
Old Apr 8, 2005 | 07:26 PM
88JDO's Avatar
88JDO
My car came with no key. I called the lock manufacturer (forgot who) and they said make an impression of the lock with some styrofoam from a cup and send it to them. I did and a few days later I had the key.
Old Apr 8, 2005 | 08:07 PM
azzkikr's Avatar
azzkikr
ALL 20 of my lugs are keyed locking lugs, of course I lost the key and the paper with the code. (Gorrilla Lugs) Now add the fact that I have aftermarket wheels where the lugs are really deep-set and not very accessible... I did pretty much what everyone else is saying... First I bought one of those universal sockets that is filled with pins, that's supposed to fit any size or shape... forget it - doesn't fit. Next I went through my "old" sockets until I found one that was a close fit, I "hammered" it on and simply used a torque wrench and removed the lug. Unfortunately, the socket was hammered on too tightly and I had to spend about an hour cutting, sawing and grinding the socket off - I couldn't get anything through the other end to push it out. Finally, I sent the lug via Fedex to the manufacturer and purchased a replacement lug and TWO lug keys (which cost about the same as I originally paid for the entire 20 lug set) Good luck, hope everything works out!
Old Apr 8, 2005 | 09:31 PM
mseven's Avatar
mseven
A method used on older wheel locks was to use a peice of conduit tubing, I.D. tight to O.D. of lock , beat on, vise grip off. Was the only way(aside from a torch ) to remove the MacGaurd style locks.
Good Luck M7
To Lug Nut Key Question-Help!!
