Suspension squeeks
Old Apr 10, 2005 | 10:40 AM
Jet-Jock's Avatar
Jet-Jock
Default Suspension squeeks
I want to toss this question out and get some opinions. All of a sudden all four suspensions have started to squeek when I go over mild bumps like the dip of the curb going to my driveway, or going over those speed bumps in parking lots, etc. For example on the speed bumps I always go over them real slow and I can now hear this squeeking.
The front is regularly and recently greased. I have all new Bilsteins just a few months old.
I'm wondering if this is all those bushings I see, but can't imagine them all at once exhibiting the exact same symptom by going bad.
And ideas?
Old Apr 10, 2005 | 10:54 AM
flylowguy's Avatar
flylowguy
And ideas?
My Vette is quiet but the Alpha Romeo makes a lot of noise. It seems to be the bushings, especially sway bar connections. I have tried a few things and what usually works (for a while) is silicone spray. It's hard to get it to go in where it needs to, but if you work at it you will shut it up.
I would guess the temperature and especially the humidity are the cause of them all getting noisy about the same time.
Old Apr 10, 2005 | 01:07 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I've had this gawdawful creaking suspension for over year. I changed the front bushings out, and it didn't go away. Yesterday I found it was one of the front spring hangers, I lubed the hell out of it and it's gone. The spring rotates a bit in there during movement. Best part is, its easy to get to.
Old Apr 10, 2005 | 01:20 PM
oldtimer's Avatar
oldtimer
I did the same thing with the same result as you. It's been six months since the lube job on the spring with no creaks
Old Apr 10, 2005 | 01:48 PM
Jet-Jock's Avatar
Jet-Jock
Are ya'll talking about the transverse spring? If so, what part did you spray down (I assume your talking about a spray lube like silicon), the whole spring?
I'm getting ready to lift the front end up to replace the primary fan motor and figured I'd address it now.
To Suspension squeeks
