Stupid light question
Old Apr 12, 2005 | 10:11 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Default Stupid light question
My car is a 1990. The headlights are manual, you turn them on when it gets dark via a switch on the dash. However, there's a little plastic round thing in the middle of the dash toward the windshiled. It looks like a light sensor like my other cars that have automatic headlights. I's in the middle of the plastic panel where the defrost blows through. What is that?
Old Apr 12, 2005 | 10:14 PM
Rane LT4's Avatar
Rane LT4
I think its a thermometer. Mine has it too and so does my 2000 silverado.
Old Apr 12, 2005 | 10:16 PM
jsup's Avatar
jsup
You have electronic air conditioning?
Old Apr 12, 2005 | 10:35 PM
Rane LT4's Avatar
Rane LT4
Yea mine is climate controlled, but it also tells you the outside temp as well. Not sure which one it would be for.
Old Apr 13, 2005 | 07:14 AM
bsimard's Avatar
bsimard
It's a sensor that measures the heat coming in through the windshield glass from sunlight and adjusts your climate control to accomodate.
Old Apr 13, 2005 | 07:21 AM
Lars87's Avatar
Lars87
I belive it is a sensor thats controlles the light in your digital cluste.....
Old Apr 13, 2005 | 08:36 AM
CREWZIN's Avatar
CREWZIN
Old Apr 13, 2005 | 09:09 AM
90TripleBlk's Avatar
90TripleBlk
No. The sensor that controls the light in the instrument cluster is located next to the controls for Range, Avg. MPG etc. Put your finger over the small opening on a sunny day and watch the cluster go dark.
Old Apr 13, 2005 | 10:15 AM
c4cruiser's Avatar
c4cruiser
It's called a "Sun Load Sensor" and it is part of the climate control system. It's there on all later C4's but only the RPO C68 Electronic Climate Control System got the components that are under the little dome.
The temperature sensor for the outside air temp display is located to the passenger side of the A/C condensor under the car where air is taken in for the radiator.
Old Apr 13, 2005 | 10:26 AM
rws.1's Avatar
rws.1
It is a noxious emissions (gas) detector. When it senses impurities in the passeneger compartment air, it opensthe baffle in the ventilation system allowing fresh air to enter the vehicle...
Old Apr 13, 2005 | 10:40 AM
krex 725's Avatar
krex 725
If that's what it is, then where is the flux capacitor??????
Old Apr 13, 2005 | 10:50 AM
DINO's Avatar
DINO
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
I went to Cruise-In V with Vetteweiser
Originally Posted by CREWZIN
Its a temp sensor ...
To Stupid light question
