plug wires
Old Apr 15, 2005 | 09:40 AM
LT1SPUD's Avatar
LT1SPUD
Default plug wires
getting ready to replace the plug wires....question..is it necessary to lift the front end to do this or can it be done just sitting on the ground?
thanx for any info!
Old Apr 15, 2005 | 10:54 AM
c4cruiser's Avatar
c4cruiser
Yes it can be done with the car on the ground. It's not an easy job especially at the Optispark on the driver's side. I removed the alternator, loosened the A/C condensor and shoved it forward, loosened the P/S pump and moved it forward and removed the serpentine belt idler pulley. There is a sheet metal bracket that holds the wires as they go under the A/C compressor that has to be removed to hold the new wires when you install them.
The wires on the passenger side are not difficult as you can easily see the wires on the opti. Just do one at a time.
If you are using the stock wires, reuse the plastic retainers. If you go to larger wires like 8.5mm or bigger, the retainers will not work unless you increase the size of the holes (use a Dremel). When I installed MSD SuperConducter wires, I tossed about half of the OEM Retainers and opened the holes in a few others and that seemed to work to keep them away from the manifolds.
The coil wire is not too difficult, just twist the wire after removing it from the coil and pull directly up from the Opti. The new wire will go on the Opti side by pushing and twisting with the dilelectric grease acting as a lube to get it to slide down and lock.
Be sure to twist the wires at the Opti to remove them. Use some dielectric grease on the inside of the boots at both ends to provide a good seal.
Old Apr 15, 2005 | 11:37 AM
LT1SPUD's Avatar
LT1SPUD
much grass.....sounds like the makings for an interesting afternoon
Old Apr 15, 2005 | 12:59 PM
96redvette's Avatar
96redvette
I just replaced by going under the car for the driver's side. I did take the serp. belt off though, made it a little easier.
Good luck
Old Apr 15, 2005 | 01:17 PM
DINO's Avatar
DINO
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
I went to Cruise-In V with Vetteweiser
PITA !!!
Old Apr 15, 2005 | 01:21 PM
LT1SPUD's Avatar
LT1SPUD
is it worth the money to let a shop do it instead?
Old Apr 15, 2005 | 03:03 PM
c4cruiser's Avatar
c4cruiser
Even if you bought a case of beer and two boxes of bandaids (and you will need both!!) it's never cheaper to take it to a dealer
It is a PITA to do but I like to work on the car, it's relaxing; well maybe except for walking across the garage a few times to recover the wrenches you just tossed or finding out that you could have taught sailors some new words and phrases....
Old Apr 15, 2005 | 03:06 PM
DINO's Avatar
DINO
I really think it is ...if you like your knuckles !!!!
Old Apr 15, 2005 | 03:13 PM
Lone Ranger's Avatar
Lone Ranger
Here's how I did it:
http://forums.corvetteforum.com/show...ug&forum_id=48
Do it yourself and save a couple hundred $$. Most shops will charge between $200 - $300 for the job, parts extra.
Old Apr 18, 2005 | 09:13 AM
LT1SPUD's Avatar
LT1SPUD
very cool!!! thanx a bunch!!!
Old Apr 18, 2005 | 11:12 AM
tinian's Avatar
tinian
Looks pretty tough and challenging, but seems worth doing yourself.
BTW, what does PITA mean?
Old Apr 18, 2005 | 11:18 AM
SDS Photography's Avatar
SDS Photography
this is a much easier job on a L98 i suppose?
Old Apr 18, 2005 | 03:08 PM
Lone Ranger
PITA = Pain In The ***
To plug wires
