Ok, this may be a stupid question, but how do I know if my 89 Z51 coupe has alum. heads?
I went to buy spark plugs, and everywhere I go to check what plugs to use, I get the same question, alum or iron heads... I'm guessing they're cast iron, but I want to be sure...
I thought the bolts for the valve covers on the aluminum's were down the center of the valve cover & for the iron heads the bolts were on the outer edges of the valve cover ? Is this correct ?
Center Bolts are Alm-Headed. All past feb of 86 have alm heads.
