Normal oil pressure?
Old Apr 19, 2005 | 10:58 PM
the oz's Avatar
the oz
Default Normal oil pressure?
I so know nothing about engines
What sort of oil pressure should I be seeing? idling? cruising at 70mph, flooring it?
87 coupe, auto
Old Apr 20, 2005 | 12:48 AM
vader86's Avatar
vader86
Depends on temperature.
Cold idle should be high 50s-60+, warm idle will be 45ish, hot idle could drop into the 20-30 range.
Anytime your foot is on the gas, the pressure needs to be over 50psi, when you floor it, it should be close to 60 or above.
Old Apr 20, 2005 | 04:00 AM
the oz's Avatar
the oz
Beauty, pretty much where I am sitting, I just didn't know if it was right or not
To Normal oil pressure?
