Tail light louvers
Old Apr 21, 2005 | 01:08 AM
The13Bats's Avatar
The13Bats
Default Tail light louvers
Someone gave me a set of tail light louvers each one has two plastic clips but how do you install these cheesy things?
Thanks,
P.
Old Apr 21, 2005 | 01:21 AM
PierEagle's Avatar
PierEagle
Look at the louver rim and you'll see an indentation at the top and one at the bottom. Set the louver in against the taillight lens, set the louvers horizontal, and push the top plastic clip in. It fits between the rim of the louver and the bezel. You may have to work at it to get it in. After the top one is seated, insert the bottom clip. The edge of the clip should seat in the prior mentioned indentations. Been there, done that. They really don't look that bad.
Old Apr 21, 2005 | 01:36 AM
EPiC Vette's Avatar
EPiC Vette
I have them on mine.
The sharp edge of the "clip" fits in between the taillight lens and the moulding (?). Just push it in. They're just as easy to remove if you don't like 'em.
-Eric
Old Apr 21, 2005 | 01:47 AM
Mystic '95's Avatar
Mystic '95
Cruise-In II Veteran
Clips??
Those are different than mine, I had as prat of the kit longer screws and spacers.
Old Apr 21, 2005 | 07:26 AM
vettefast's Avatar
vettefast
The clips fall out too easy. I used a thin layer of weather strip glue on the back of each one and attached them directly to the lense
Old Apr 21, 2005 | 07:52 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Originally Posted by Mystic '95
Clips??
Old Apr 21, 2005 | 09:15 AM
LT1SPUD's Avatar
LT1SPUD
mine had the longer screws and spacers too....here's how they look installed...........
Old Apr 21, 2005 | 09:44 AM
EPiC Vette's Avatar
EPiC Vette
Oh, yeah. I've got the round taillights. I forget there's different C4's!
-Eric
Old Apr 22, 2005 | 11:26 PM
The13Bats's Avatar
The13Bats
I have the round tail lights that use the clips but I think I like the idea of a bit of clear silicone to hold them,
I love some of the cheesy as I called them one hour custom items,
cheers,
P.
To Tail light louvers
