keyless entry problem OR dead battry
Old Apr 24, 2005 | 05:33 PM
XavierLT-4's Avatar
XavierLT-4
Default keyless entry problem OR dead battry
I went to start my car and nothing, no clicking from the battery, I checked the fuses that were related to the engine and ignition, I checked the battery in the keychain...all are fine. If it is the battery can I try charging it with a small plug in battery charger (marine battery charger) without damageing the electronics?
What is the best way top remove the battery (if that is the case) LT4 the batteryu really seems to be wedged in at an od agle without ready access......
I really appreciate any help I can get out there!
Old Apr 24, 2005 | 06:45 PM
Red Dwarf's Avatar
Red Dwarf
In the event you have to change the battery this site shud help.
http://www.corvettemagazine.com/2001...ttery/bat1.asp
Old Apr 24, 2005 | 08:23 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Same thing happened to me this morning. It was a dead battery. I accidentally flicked the interior light switch on and it drained overnight.
Old Apr 24, 2005 | 08:38 PM
Dandy97's Avatar
Dandy97
Same thing happened to me on Friday. Went to start up the Z and no crank, nothing. Thought it might be the clutch switch but it checked out OK. Thought it might be VATS but it seemed to be working OK. Replaced the battery today and it fired right up. I load tested the battery and it wasn't holding a charge anymore. Glad it was something simple. It's no fun putting a battery in a C4 though.
Old Apr 25, 2005 | 03:52 PM
bsimard's Avatar
bsimard
Good grief. It must be the moon. I went out to my '95 this morning and the doors didn't click open, and the key turned with nothing. No click, no ignition, no horn, nothing. Interior lamp switch was left on. What idiot did that?
Old Apr 27, 2005 | 03:04 PM
koolaid117's Avatar
koolaid117
Ok, what about sorta turns over then clicking. Only clicking after that?? Still the battery??
To keyless entry problem OR dead battry
