Where to find front upper window stop?
Old Apr 26, 2005 | 09:34 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Default Where to find front upper window stop?
Did the outer window weatherstrip change. Took about and hour and put it all back togther and went for a ride. Hit a bump heard a little pop and a tink of something hitting the window I thought mabey a bolt I forgot to tighten. No such luck it was the front upper window stop figured it out when I got out and almost broke the window when I shut the door because the front edge was about 1/2 inch too high. Took the panel off and yep there is nothing attached to the upper stop except the back part of the plate the edge that stops the window is gone. Now where do I find one I found the lower stop but can't find the upper one. Any suggestions?
Old Apr 27, 2005 | 02:34 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Try Contemporary Corvette, link on my site.
Old Apr 27, 2005 | 10:43 AM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Or www.vette2vette.com
To Where to find front upper window stop?
