Whats Wrong With This Shock ???
Old Apr 29, 2005 | 02:47 AM
Wayne88's Avatar
Wayne88
Default Whats Wrong With This Shock ???
I installed this shock, new, about a month ago, has less than 400 miles.
Its scraped, it wasn't like this before I installed it.
Whats wrong with it ??? Thanks in advance.
Old Apr 29, 2005 | 03:21 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
There's a ring seated at the top of the shock shaft, if this isn't perfectly aligned, or the hole in the shock boot isn't just right, the boot will sit cockeyed like that.
It's not a problem, just a nuisance. Try pulling the boot outward and see if it stays centered better. All the boot does is help keep the shock shaft clean.
Old Apr 29, 2005 | 10:56 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Most shocks will do this. Other than causing us great aesthetic anguish, it does no harm.
Larry
code5coupe
Old Apr 29, 2005 | 11:10 AM
Wayne88's Avatar
Wayne88
Thanks guys.
So the shock is OK, its the boot that needs to be centered.
I appreciate your input
To Whats Wrong With This Shock ???
