L98 Starter replacement question
Old May 4, 2005 | 09:29 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Default L98 Starter replacement question
Gonna do this tomorrow. I have never done a C4. Is it similar to the C3? The GM manual says to remove the flywheel cover. Never had to do that on a Chevy before.
Any tips/shortcuts are appreciated.
Old May 4, 2005 | 09:35 PM
_twisted_'s Avatar
_twisted_
4 screws hold the cover on
Use a hold back on the B+Cable so you dont crack the solenoid cap.
1 locator stud on the front side of starter and 2 bolts. yer done
Old May 4, 2005 | 09:48 PM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
Not sure what year c4 calls for that because on my 90 only 2 bolts free the starter. No cover removal needed.
Old May 5, 2005 | 06:41 AM
rons85's Avatar
rons85
It's no different that any other SB chevy - about the same as doing it on a 2wd full size pickup. Simple as it gets.
Old May 5, 2005 | 06:54 AM
86PACER's Avatar
86PACER
You don't have to remove the flywheel cover, but I do because it makes it easier.
To L98 Starter replacement question
