4+3 button fix
Old May 5, 2005 | 03:35 PM
Sodakrep's Avatar
Sodakrep
Cruising
Default 4+3 button fix
I tried a search and found nothing. I know there has to be something on this board about fixing this in a 87. How much does this generally cost. I am looking to buy one and the button does not work and I want to use this in negotiations. What is the most common source of the problem? Is it the button itself or the overdrive unit? Thanks for your help.
Old May 5, 2005 | 07:29 PM
Der Flieger's Avatar
Der Flieger
Default 4+3 overdrive
Below the gearshift lever, under the boot, the is a rod that goes down from the switch button to actuate a micro-switch that engages and disengages the O/D operating through the computer. This switch appears to have come from Radio Shack, but such is not the case. It cost me (hold on to your hat) $120.00 from the dealer. That was the only place I could find one. Perhaps a wrecking yard or salvage yard may have one. They are very fragile,so use care. A simple continuity check can tell you if it is working or not.
Old May 5, 2005 | 08:26 PM
scorp508's Avatar
scorp508
If you buy it from Ecklers it is $125. If you buy it online at another vendor it is $11, but without the wire harness (easy solder job to transfer it).
Oh yeah.... common source is just the button going bad. This is assuming that the overdrive works perfectly except for manual override with the button.
Old May 5, 2005 | 08:27 PM
ballox's Avatar
ballox
contact 88BlackZ-51 he fixed his for a few dollars on his own
Old May 5, 2005 | 08:34 PM
scorp508's Avatar
scorp508
...but then he'll be contacting me again looking for where that is.
http://www.newark.com/
For 1986-1988 use P/N: 61F753
Ooops sorry, it is $12.30 now.
http://www.newark.com/NewarkWebComme...SKU=61F753&N=4
Old May 7, 2005 | 03:29 PM
ddorlando's Avatar
ddorlando
I have the same problem with my switch, I just went down to radio shack and bought a switch, but I think I got the wrong kind. Anyone know how the factory switch function. When I wire it, the over drive is alway off. Then when I press the button , over drive comes on. When I release the button, overdrive goes off. If I switch the wiring, it does the same, but opposite. Is the push button switch supposed to work like a toggle. ie. press it for 12 volts, then press it again to toggle it off?
Old May 7, 2005 | 05:09 PM
ddorlando's Avatar
ddorlando
Nevermind, I bought a momentary switch, when I needed an on/off switch. Only cost $3.50 or so a Radio Shack.switch The second one on the right is the size you want, but make sure it when you go get it isn't a momentary switch, they have both. The one you want has a red top. Not bad for a $140 factory part!
Old May 7, 2005 | 05:51 PM
scorp508's Avatar
scorp508
Switch types...
84-85 = On/Off
86-88 = Momentary On
Old May 8, 2005 | 04:33 PM
eightysixcoupe's Avatar
eightysixcoupe
It may be just a frayed wire at the switch like it was on both my and my father's 4+3 equipped cars, it's a common problem. The wire fatigues and frays to the point at which it breaks off the switch's solder tab. I soldered the harness to the ground and normally open (N O) leads on the switch and it worked perfectly. After determining the switch was good, the overdrive still did not work. I believe the bad connection in the switch caused the relay to fail, $17 for a new relay and I was back in business.
Good luck.
To 4+3 button fix
