Tow Straps????
Old May 10, 2005 | 06:40 PM
Brett Richmond's Avatar
Brett Richmond
Default Tire Straps????
I need to know where the cheapest place to order the tire straps are???
I need to take my car to bowling green for CF weekend, any help would be appreciated.....
Old May 10, 2005 | 08:40 PM
Carl Johansson's Avatar
Carl Johansson
Tow straps or tire straps? can't tell - you mention both.
Ratcheting tie down straps - heavy duty 2.5 - 3 inches wide can be had at home depot relatively cheap. costco has em even cheaper if you can find them. Harbor Freight has tow straps and Tie downs very cheap - I use em and they work fine - but there will be disention on this point - cheap made in China stuff - no good - etc.
Carl "they work for me" Johansson
Old May 10, 2005 | 10:00 PM
Brett Richmond
Tire straps is what I really want, if you use the tow straps, exactly where on the frame is the mounting points at?????
Old May 10, 2005 | 10:02 PM
c4cruiser's Avatar
c4cruiser
Both Summit Racing and Jeg's has tire straps for holding the car on trailers. Go to www.summitracing.com and in the search box, enter these part numbers:
SUM-G7950
SUM-G7955
HIG-12707
HIG-91711
HIG-12750
HIG-12755
If you use the over-the-wheel tie-downs, you should also have another strap or chain (front and back) attached to the frame and to a ring on the trailer floor.
Also check out trailer sales places and RV shops. You should be able to find good strap setups there.
Old May 10, 2005 | 10:23 PM
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
Best I can say how to explain it is...
On the front, open the hood - where the inside of the fenderwell starts to curve back around, reach all the way down and under and you will feel the oval hole inthe tab fromthe frame - one is on each side.
On the back, lay on your back and put your chin at the FRONT of the REAR tire - look up and in front of the suspension, you will see it hanging down slightly - again, it is an oval in a tab hanging down from the frame, one on each side.
Hope this helps - I have the blue straps from Jegs
Old May 10, 2005 | 10:56 PM
Brett Richmond
Thanks for all the replys, they are all appreciated and will help in getting my broke car to bowling green!!!!
To Tow Straps????
