cat removal
Old May 11, 2005 | 06:43 PM
GOOG's Avatar
GOOG
Default cat removal
Is there a big power gain in removing the front 2 catalytic converters? I'm thinking of doing away with them and was wondering if it would be noticable powerwise.
Tom
Old May 11, 2005 | 07:55 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
What year car? what motor? Any other mods? If it is an L98 car, removing the 2 precats is beneficial, but removing the main cat, or cats on the LTx motors is a waste of time. They can flow well enough to have over 400hp run thru them without any hinderance. All you are going to do by removing your cats is add pollution to our ozone and make your car louder
Old May 11, 2005 | 08:11 PM
bogus's Avatar
bogus
I cannot agree more with what kwik_ta just said.
I don't really care if you have no emissions tests, its all about doing the right thing... and leaving cats on is doing the right thing. It's that simple.
As for loss of power? Expect the LTx cats to cost no more then 5hp. Wow. A lot...
Old May 11, 2005 | 08:14 PM
vader86's Avatar
vader86
You must tell us the year of the car
Old May 11, 2005 | 08:21 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
He has an '87.
Tom, I recommend getting headers, that kind of solves the precat problem.
Tommy's friend has a Random Tech cat on his '89 with LT headers and has no problems.
Old May 11, 2005 | 08:35 PM
CREWZIN's Avatar
CREWZIN
I replaced the pre-cats with a new larger "Y" pipe without the cats. I still have the OEM CAT in the middle. It is a little louder (not very much) and it's probably just my imagination (or wishful thinking) but it seems to have a little more get-up-n-go from a standing start.
Old May 11, 2005 | 10:08 PM
vader86's Avatar
vader86
Ok, just remove the front Y-pipe and manifolds and add headers.
The front cats are useless after the engine is hot, if the main cat is in good condition.
To cat removal
