Late C4 owners, a question
I like to look at both the digital and analog temperature readings, it lets me keep a close watch on my cooling system. If there is a large split I know something is wrong.
What does your cluster display most of the time?
I have owned to many hot running Corvettes and have become parinoid. My car never sees 200 now with the Be-Cool but I still am always looking to see where the temp is.
I usually do a cycle-through of my temps as I'm driving. Unfortunately, I do a lot of city driving, and I try hard not to rev the engine too high until it's warmed up. That said, I'll usually start out with it on "Oil Temp," and as the temps climb, I'll cycle through Oil, Coolant, and Inst. MPG. If I sit in traffic for extended periods of time, I usually leave it on Oil temp. I have a new WP, and with the A/C on to trigger the fans, I don't worry much about coolant temp (rarely goes above 205 with the fans on, even after sitting in traffic for extended periods). The oil temp, OTOH, has been known to get up there... I once neglected switching the A/C on, didn't bother to change the readout to display oil temp, and when I finally *did* remember, my oil was at 238.
Not lethal, but I was less-than-enthused. I can only imagine what my tranny temps were - for the first time, I could "feel" the sluggishness in the tranny when starting. Maybe it was just the engine bogging from heatsoak, but I definitely thought I felt some slippage that I normally do not feel.At any rate, in freeway situations, I'm almost 100% of the time on instant MPG...I really try to maximize it as much as possible. Anyway, hope that helps.
BTW - my odo's at 51,502, and no, I didn't just go out and look!
Sometimes I'll leave it showing the Coolant temp, but will cycle between them from time to time.
I usually don't leave it set to display the Average fuel mileage too often as I hate to watch it drop while at a stoplight!
I will check the average fuel occasionaly though to see what kind of damage I've done with my right foot!
On road trips, it's always on average MPG or RANGE, but around town, oil temp.
Due to a few disasters caused by my own negligence in my early days,
I watch those analog gauges instinctively, and I like to see them all at the same time.......I've done it so long it is just habit...I always know the status of my engine, and I've found the analog gauges are close enough to let you know if you have a looming crisis, especially if you check them frequently.
:me to...Well up unto that mileage thread ....I couldn't stand to look at that 128,000 and counting everyday!
