Best Replacement Battery??
Old May 19, 2005 | 08:05 AM
Greg Gore's Avatar
Greg Gore
Default Best Replacement Battery??
What do you recommend to replace a failing battery; new Delco Remy or one of the gel types? Did the later C5's have a Delco gel type battery?
Thanks, Greg
Old May 19, 2005 | 08:16 AM
rws.1's Avatar
rws.1
A number of people report failure of the Delco batteries due to separation of the terminal from the battery.
Others have been given the run around by Interstate on honoring the warranty.
Some of the most recent favorable posts have been on Walmart... Great price and no hassle warranty.
Old May 19, 2005 | 08:18 AM
Aquaman92's Avatar
Aquaman92
I have a interstate battery works fine,The Optima Gel cell does not make a battery as far as I know that fits a C4 without being modified.
Old May 19, 2005 | 08:19 AM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
I recently replaced mine with a NAPA product. Good warranty, exact fit and the price was around $70. This was their heavy-duty model. The only difference between this and the more expensive one was the length of the warranty.
I lked it because it only had the side mount. The last one that the previous owner installed had dual mounts and I was always worried about the top mounts hitting something or something hitting them and arcing. I had those plastic protectors on top of them but still did not like it.
Old May 19, 2005 | 08:37 AM
wgc_3's Avatar
wgc_3
As much as I hate to say it Corvettes from my aspect are bad on eating up batteries. All three of Corvettes have had atleast one battery change when in two weeks of me owning them. If you go down to your local parts store ask for a red top battery (optima) I promise you will never want to buy another battery!
Old May 19, 2005 | 08:42 AM
Muffin's Avatar
Muffin
I have seen this stated more than once. I must have done something cause my Optima went right in without a problem. Ignorance is bliss.
Old May 19, 2005 | 08:47 AM
mseven's Avatar
mseven
Thanks, Greg
I prefer using "deep discharge" or "deep cycle" type batteries. All the companies make them.
Old May 19, 2005 | 08:53 AM
Kwikerthanu's Avatar
Kwikerthanu
St. Jude Donor '05-'06
Mine came with an Interstate, but when it comes time to replace it an Optima is going in.
Old May 19, 2005 | 09:06 AM
Aquaman92's Avatar
Aquaman92
Interesting I have read more than 1 thread that stated the Optima battery did not fit without cutting off the top posts.
Old May 19, 2005 | 09:23 AM
Saisling's Avatar
Saisling
St. Jude Donor '05
I believe I'm probably running the same battery as corvetteronw - Napa with side posts (no tops) with a good warranty and it was around $70. I put it in last year.
Didn't drive the car much over the winter and, in my opinion, it died quickly even with no use... but I hooked a trickle charger to it and it's been fine ever since...
Old May 24, 2005 | 06:10 AM
vetteheadracer's Avatar
vetteheadracer
2022 C7 of the Year Finalist - Unmodified
What model Optima Battery fits in a C4? I have a 1996 LT4 and I want to fit a red top or yellow top (have a yellow top in my C5).
Please let me know as I want to buy one this week.
Old May 24, 2005 | 06:17 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I haven't bought my Optima yet, but someone somewhere was spreading a rumor thatthey were making a sidepost only one soon, si that's the one I'm waiting for.
Currently I have NAPA Gold(which is almost due for replacement)in my '95 and in my '93 I have an Exide/NAPA gel battery that is similar to the Optima. You need to cut the top post off any battery that has both kinds to clear the PCM bracket(or cruise control depending onthe year). Also, you have to trim two itty bitty tabs in the battery tray. That's it.
Just stay away from the AC Delco battery.
Old Jun 4, 2005 | 03:09 PM
Jim Nichols's Avatar
Jim Nichols
Can't answer about Optima, but run, do not walk, as fast as you can get away from INTERSTATE. Their Johnson Control batteries are likely the same as Die Hard, but INTRESTATE's customer service is horrid. See this CF link.
http://forums.corvetteforum.com/show....php?t=1031134
Jim
Old Jun 4, 2005 | 03:15 PM
ruby4me's Avatar
ruby4me
I replaced mine with an Autozone Gold with side posts only. Seems to work well. I believe Johnson Controls makes the Autozone batteries as well.
RUBY4ME
Old Jun 4, 2005 | 03:20 PM
Jim Nichols
Anything but INTERSTATE. Horrid Customer Service. See this CF thread.
Old Jun 4, 2005 | 05:42 PM
LT4play's Avatar
LT4play
I beleive the source of this is the Corvette Fever magazine from a couple months ago..
Old Jun 4, 2005 | 08:04 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
All the batteries seem to be relabeled crap.
I buy whatever has the best warranty. Sears is nice, because exchange is so easy there.
I think a deepcycle battery is a poor application for a car.
Old Jun 4, 2005 | 08:05 PM
CentralCoaster
Maybe it was me too. I spoke to a optima rep at a tradeshow early last year, he said a side post would be available for that size soon. But those guys tend to nod their heads like a duck, so take it for what its worth.
Old Jun 4, 2005 | 08:51 PM
Lone Ranger's Avatar
Lone Ranger
http://www.uuhome.de/william.darden/batbrand.htm
The above link is an eye-opener as far as who makes what brand batteries. Lot of the name brands are made by a couple few large manufacturers such as Johnson Controls.
I just replaced a NAPA 75 month battery with a Duralast Gold. Yeah, I know. But The Duralast is made by Johnson Controls and they make a variety of brands including the Diehard, so I figure it's okay.
I only replaced the NAPA due to age (preventative maintenance), no symptoms yet, but it was installed in the car by the prev owner in 2001, and I don't trust batteries past 3 or 4 yrs regardless of purported "warranty".
To Best Replacement Battery??
