Cleaning under the emblems
May 24, 2005 | 12:35 AM
See
THIS for an example of what I am going to say.
How do get the tight spots in the emblems clean, this black stuff really close to the badge in a corner.
Or from between the letters on the script on the back bumper.
It's driving me crazy
May 24, 2005 | 12:39 AM
Easy - just unscrew them from behind - clean them up and then put them back and screw them down.
Be careful as the nuts are weird and screw onto plastic posts.
May 24, 2005 | 12:44 AM
Gotta be something easier than that.
This is the hood and the rear bumper, neither of which are very easy to get the screws.
Fuel door, no probs, these two, I'll live with dirty.
May 24, 2005 | 12:48 AM
The hood is dead easy to do - 10mm socket on an screwdriver adaptor - 30 secs and it's done.
Rear bumper is a pig
May 24, 2005 | 12:49 AM
I thought with the front it was very easy to lose the nuts....
I might have to look closer when I'm at home
Thanks mate
May 24, 2005 | 02:05 AM
Just use a magnetic screwdriver or keep a magnet handy
May 24, 2005 | 02:18 AM
I use a tooth brush with soft brissils with a little wax on it for those tight areas. Then a clean one to get the wax build up out. You can even put a layer of say a white t-shirt between the brissils and the car for better cleaning. A single layer of a t-shirt is thin, but can collect alot of dirt. The wax will break up the dirt better than dry, and not dig the dirt into the paint.
I think you'll find that to be what you are looking for.
May 24, 2005 | 07:20 AM
You can buy a detailing brush wax around emblem use the brush to remove excess wax.To much work in MHO to take the emblems off.
May 24, 2005 | 10:17 AM
Finalist 2020 C4 of the Year - Modified
I'd use a toothbrush as stated, then once they were clean I'd use either Rejex or Meguiar's NXT. They leave no white residue.
May 24, 2005 | 11:19 AM
St. Jude Donor '05
If your going to remove the emblem from your hood, it's not too hard. Just make sure the motors cold
And like others said, keep a magnet handy. You don't want to drop one of the nuts down inside the hood while your taking it off. Thats the hardst part...
