Alternator Bad?
Old May 29, 2005 | 11:35 PM
Brtheez's Avatar
Brtheez
Default Alternator Bad?
I had been noticing that my turn signals would slow down when I would brake and when driving at night the lghts would dim when slowed down to a stop. I'm not exactly sure what the correct battery voltage is supposed to be, but it has been running as low as 11.4 and as high as 14 when driving at normal speed. Anyway I decided to stop at Advance Autoparts and have them check the battery and alternator. They said the alternator is showing a bad diaode path. They suggested I take it out and have them bench test it. Should I go throguh the trouble of taking it out or should I trust what they tell me? In addition any hints or information on taking the alternator out? Thanks.
Old May 29, 2005 | 11:42 PM
FD2BLK's Avatar
FD2BLK
You need to pull it to replace it any way so why not get it tested while its out?
To pull it
Disconnet the bat.
Pull the belt
Remove the bat. wire (The big Red one) from the back of the alt
Disconect the connector
Remove the two bolts that hold the alt. to the motor (One on top one on bottom)
Thats about it It's a 15 min job, just reverse the order to install the new one.
Old May 29, 2005 | 11:49 PM
okies93's Avatar
okies93
St. Jude Donor 06
nothing to it
Old May 30, 2005 | 10:39 AM
Brtheez's Avatar
Brtheez
Seems pretty straight forward. The last time I changed an alternator was when I was 16. It was a Chevette. I was trying to get to the Vette part. I finally got there 18 years later. Anyways, you state to pull the belt. How do I go about doing that. Previously I unbolted the alternator and the belt then came off. Is there anything special I should be looking for with the belt. How hard is it to get the belt back on the pulley? Thanks.
Old May 30, 2005 | 03:48 PM
fasttrack87's Avatar
fasttrack87
Cruising
On the front of the belt tensioner the is a 1/2" socket for relieving the tension on the belt. I use a breaker bar or rachet. Justr pull the tensioner away from the belt. The also make a tool for this.
Old May 30, 2005 | 04:46 PM
Brtheez's Avatar
Brtheez
Thanks for the information. I have one last question. Does anyone have an opinion on alternator brand? I looked on Rockauto.com and it gives about 5 options. Oh and one other thing. Speaking of the tensioner, the tensioner makes a knocking sound. I presume may be bad bearings. Should I go ahead an replace it at the same time?
Old May 30, 2005 | 07:10 PM
jfb's Avatar
jfb
Replace the tensioner too! I have installed two Delco alternators on my 87 which is driven every day and now has 200k (bought at 36k). Your battery voltage should never get to 11.4 volts. Normal battery voltage is 14.3 volts engine cold, 13.3 volts engine hot. It is normal for the alternator output voltage to drop with increasing temperature.
Old May 30, 2005 | 07:15 PM
the oz's Avatar
the oz
Just to let you know, I had the same issue, the alt was fine but the regulator was bad.
Replaced this small part as opposed to the whole thing. Lots cheaper.
To Alternator Bad?
