Muffler Paint?
Old May 31, 2005 | 08:53 AM
BillK's Avatar
BillK
Cruising
Default Muffler Paint?
On my 92 it looks like the mufflers/exhaust tips are painted black. I am assuming this was from the factory as nothing else on my car was modified in any way when I bought it. That said, the paint is peeling badly and starting to look bad.
I am considering putting Corsa's on, but am having a hard time selling the wife on the cost. Does anyone know if I can sand the mufflers down and repaint? If so, with what type of paint?
Old May 31, 2005 | 09:18 AM
HOOBS's Avatar
HOOBS
This may sound a bit odd....But if you want them to remain a "flat" black and you are concerned about the high heat....I would try BBQ flat black paint in a spot where you won't see it...and then see if it flakes off or not. This type of paint you can get at your local hardware store...it's used for re-furbishing BBQ'S.
Old May 31, 2005 | 09:19 AM
NC2Stay's Avatar
NC2Stay
I just did it. Degreased and sanded, then 3 coats of slightly glossy (not flat black) Krylon gas grill paint. Came out very well, but can't give you any long term answer as I just did it last week!
Bob
Old May 31, 2005 | 10:25 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Old May 31, 2005 | 11:55 AM
Strick's Avatar
Strick
I used one of those 500 degree ceramic paints after cleaning and lightly sanding, but that was a few years ago. It worked just fine and looked much better. My B&Bs look even better.
Old May 31, 2005 | 11:59 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
It works.
Larry
code5coupe
Old May 31, 2005 | 02:09 PM
BillK's Avatar
BillK
Cruising
Thanks for the help.
Now, do I have to drop/disconnect the mufflers to do it?
Old May 31, 2005 | 07:02 PM
-=Iron Mike=-'s Avatar
-=Iron Mike=-
Yep, BBQ paint. I have a can right now and it's good to 1200*. Right after I paint the BBQ, I'm re-doing the exhaust tips.
Old May 31, 2005 | 08:18 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Old May 31, 2005 | 08:19 PM
okies93's Avatar
okies93
St. Jude Donor 06
just paint what can be seen. use newpaper and cardboard and tape.
Old May 31, 2005 | 10:03 PM
Hogan's Avatar
Hogan
From: First to Sign Grumpy's Hat Only 53 miles from Hell
St. Jude Donor '06-'09-'10-'11
I used good ol flat black engine paint. Every couple of years just do a touch up from the rock chips.
Old May 31, 2005 | 10:07 PM
84GSCLONE's Avatar
84GSCLONE
I used BBQ paint for my Monza tips when they started to fade ... works like a charm!
Old Jun 1, 2005 | 06:52 PM
hip_about_time's Avatar
hip_about_time
...does that stuff come in other colors? Red resonators with silver tips might look good...
Old Jun 1, 2005 | 10:47 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
I did mine withn the BBQ paint 3 years ago...still look good..a piece of cardboard to cut down on the overspray and your good to go...btw, I had to do it quick at the time so no cleaning or sanding and it's fine...
Old Jun 1, 2005 | 10:59 PM
mauricewoodard's Avatar
mauricewoodard
i did mine also, but i used the hi-temp engine can spray paint at your local auto parts store it turned out GREEEAAATTT!!!! JUST MAKE SURE YOU SAND IT REAL GOOD AND COVER UP FOR THE OVER SPRAY
Old Jun 2, 2005 | 08:08 AM
BillK's Avatar
BillK
Cruising
Thanks for the info. everyone.
To Muffler Paint?
