Idle Speed?
Old May 31, 2005 | 12:54 PM
chimknee's Avatar
chimknee
St. Jude Donor '06
Default Idle Speed?
I have an 96 LT1 with the A4. With the tranny in neutral, I'm taching just shy of 1000rpm. When I'm waiting at a light, I have to stay on the brake fairly strongly to keep from moving. Most times at long lights, I put it in neutral. Is this a little high for idle speed?
Old May 31, 2005 | 02:09 PM
Saisling's Avatar
Saisling
St. Jude Donor '05
I don't know what most LT1s are running, but that sounds slightly high... my L83 idles around 700-800 in Park/Neutral and drops to about 600 when I put it in gear.
Since you only gave what your idling in neutral, should I assume your running a manual trans? And, if so, why should your idle speed cause you to press on your pedal harder at a light? The engine would be disengaged with the clutch in. If it is an auto, whats your idle speed in gear?
Old May 31, 2005 | 10:22 PM
chimknee's Avatar
chimknee
St. Jude Donor '06
A4= Automatic 4 speed.
Old May 31, 2005 | 10:29 PM
okies93's Avatar
okies93
St. Jude Donor 06
my 93 with a4 idles when at normal op temp around 6-700 in park, in gear at red light is at 5-600. first thing in morning mine idles likes yours at 1000 and it takes a heavy foot to keep her from moving.
Old May 31, 2005 | 10:35 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Dah!
OK!
To Idle Speed?
