E-break
Old Jun 15, 2005 | 07:58 AM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Default E-break
My e-brake works fine, EXCEPT it has decided that it will not lock when pulled back.
If I hold it in place, it's OK. It won't click and stay in place. It springs back to the normal position. That catch mechanism isn't worknig. It's as if the release button is pushed in all the time.
I have to take out the seat to fix it I assume. Is this a real PIA?
Is fixing it a PIA?
Old Jun 15, 2005 | 08:24 AM
Steel Blue 91's Avatar
Steel Blue 91
Sounds like the ratchet mechanism is "gunked" up. You'll need to pull the seat and the Ebrake cover to get to it.
Old Jun 15, 2005 | 08:40 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
No big deal John:
-move the seat back, remove the plastic covers over the two front bolts and the nuts.
-move the seat forward and remove the two rear nuts
-lift the seat a little and open electrical connector under the seat
-remove the seat and set it aside
After removing one screw the E-brake cover should come off to reveal the lever and rachet mechanism.
Old Jun 15, 2005 | 07:57 PM
jsup's Avatar
jsup
How complex is that mechanism?
Old Jun 15, 2005 | 10:09 PM
Thrak's Avatar
Thrak
Isnt that how its supposed to work? If the handle stayed up then it would be a real pain to get out of the car!
Old Jun 16, 2005 | 06:46 AM
-=Iron Mike=-'s Avatar
-=Iron Mike=-
I'm also a little confused as to what your problem is.
Old Jun 16, 2005 | 07:12 AM
jsup's Avatar
jsup
This is exactly what happened.
I pulled it, it stayed up, and I couldn't get out of the car.
So I pushed in the button and released it to put the handle back down so I can get out.
Since that time the e-brake didn't "catch" it pulls tight, the brake works, but it won't stay engaged to hold the car. It doesn't do the clicking thing when it's pulled tight.
Is it supposed to hold tight then go back down?
Old Jun 16, 2005 | 09:25 PM
MYCoupe's Avatar
MYCoupe
It's supposed to hold and click when you bring the handle up. Then, you can push the handle down again (w/o pressing the button) and it will hold. To release it bring it up again and lower it while holding in the button.
Old Jun 17, 2005 | 09:24 AM
jsup's Avatar
jsup
Thanks.
To E-break
