I'm looking for some suggestions on what to use under my jack stands to prevent them from sinking into my asphalt driveway. It's usually not a problem but with the temperature being as high as it was earlier this week, the stands sank into the soft asphalt. I was thinking of using some plywood but wood scares me since it splits pretty easily. Thanks for any input and suggestions..
Rather than ply wood, I'd rather use pieces of say 2X10 or 2X12 depending on the size of your stands. Or, go for some sheet metal and weld the stands to it.
I would get some 1/8" steel plate about a foot square. Round off the corners and add a non-skid paint to both sides. Drill a hole in a corner or on a side edge so you can hang them up when they're not in use.
Use 3/4" plywood squares with rounded edges. Works great off-road and should work every bit as well on asphalt. In the event weight applied to a piece of solid wood is too great the wood will snap in two. Heavy plywood will NOT do this unless maybe your putting the weight of a tank on it. My opinion, no scientific proof.
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I think wood is the best idea.. They won't slip, the jackstands will cut into em.. They won't split either since part of the jackstands will always run sideways to the grain. Plywoods an even better bet.
Or, get some of those thick rubber floormats and cut them up.
I don't particularly like getting under a vehicle on jack stands, even with them setting on a flat concrete floor. No way would I get under one where the jack stands are setting on wood or a steel plate unless the steel plates are welded to the jack stand legs. If your stands are sinking into the asphalt a better method would be to buy 2 sets of ramps. Drive the front wheels up on ramps and then use a jack to raise the back and place ramps under the tires. I can't bench press 3,200+ lbs of Corvette.
I like this idea, I'm going to do this so I won't tear up my new garage floor coating -- when ever I get around to it
IMHO, I would either: A) wait B) rent a space (if the job is that urgent)
Not only are the stands going to be an issue if the asphalt is that soft but the floor jack will sink the wheels. The steel plate idea would help, but I just dont believe any job is that urgent to risk safety over.
As to those wood blocks, well all I can say is I wouldnt be under there with just that alone (same goes w/plywood). Choose saftey first
Thanks for all the great suggestions. The only reason I need to use the stands is to swap out winter wheels with summer wheels. I'm not doing any under car work. I have a kwikLift in the garage for those repairs. It's just a PITA to do the whole lift thing just to swap wheels. I like the plate steel welded to the stands idea. Have a Great Fathers Day all of you Dads out there
