heater/ac control unit
Old Jun 18, 2005 | 01:12 AM
culuknn2's Avatar
culuknn2
Default heater/ac control unit
in my 89 my ac/heater control unit is electric and sometimes it goes haywire and the lights blink off and on and the numbers change and it cuts off and on by itself.is the unit going bad or is this normal.
Old Jun 18, 2005 | 01:16 AM
SunCr's Avatar
SunCr
It didn't come from the Factory that way - it needs to be replaced though some have luck with taking off the face plate and cleaning the contacts.
Old Jun 18, 2005 | 01:32 AM
culuknn2's Avatar
culuknn2
Default ac/heater unit
thanx i appreaciate the help from everyone
Old Jun 18, 2005 | 07:10 AM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
I took mine out. You have to remove the center trim, then there are 4 - 7mm bolts that come out. It just unplugs. Use a clean pencil eraser to burnish the contacts or spray contact cleaner. It did not help mine. (an 87). The AC/heater functions OK I just would like to have the correct display. You can get a used one from www.vette2vette.com or www.contemporarycorvettes.com
Old Jun 18, 2005 | 11:35 PM
mjones's Avatar
mjones
Yep ! My '91 has done that a few times. My dad has a '95 and his has acted up before also. These cars do crazy things.
Old Jun 18, 2005 | 11:48 PM
Jim Nichols's Avatar
Jim Nichols
Had same problem. After checking the forum, I let the dealer fix it for $429.00
Old Jun 19, 2005 | 01:16 AM
jfb's Avatar
jfb
DO NOT take an eraser to the gold plated pads on the circuit board!!! You will have connection problems forever, guaranteed. Use either electrical contact cleaner spray or a cloth and alcohol.
If cleaning the connectors doesn't help, then you will have to remove the control head and take it apart to where you can see the circuit boards. Using magnification, examine each solder joint and reflow those that look defective. Also, there is a row of about 1/4" diameter eyelets with a miniscus of solder across each one and these solder webs crack causing the problems you experience. Reflow these if you see poor solder joints on these large eyelets.
To heater/ac control unit
