sticky ignition switch
Old Jun 22, 2005 | 03:41 PM
1988roadster's Avatar
1988roadster
Default sticky ignition switch
some times my ignition switch will stick and hold the starter drive in. What needs to be done to cure this?
Old Jun 22, 2005 | 10:53 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
You can buy a new one from www.corvetecentral.com
It comes with a non-VATS key so you will have to go to a key shop and get 2 keys cut. Take your old ignition key with you so they can measure the resistance in your original key's pellet.
You will need a steering wheel puller and a lock plate puller.
Do a search here and at www.corvetteactioncenter.com to find tips on how to do this. It really helps if you can get hold of a shop manual.
You may be able to rent the pullers from Autozone or Pep Boys. I bought mine from NAPA for about $25 each. I had my keys cut at Sears for about $50 and the new switch cost about $50 also.
You won't notice the cost once you get it working!
