Oil Change
Old Jun 24, 2005 | 12:08 PM
Brian Blum's Avatar
Brian Blum
I have to use 2X4's in a stair step design and rams.....so there is no scraping.....I have what are suppose to be low profile ramps.
Old Jun 24, 2005 | 12:30 PM
Phantom90's Avatar
Phantom90
Originally Posted by jsup
What would be better, an oak plank or a pine one. Or ramps, metal or plastic? What about a filter wrench, strap type or bottom type? AC Delco or Fram? Synthetic or dino? Cotton rags or polyester to clean up? GOJO or LAVA? SK or Craftsman?
LT1s are an easy change out. I would go with the metal ramp, I dont trust plastic for some reason. just make sure to inspect the welding every once in awhile as a precautionary measure.
I used the Fram oil filters in my 95 Z28 and didnt need a filter wrench. They came with the black grip on the oil filter made changing very fast. I hate filter wrenches.
I always llike the synthetic. The advances in modern science are more exact than what occurs in nature.
And whatever rag you have with in reach would work.
Craftsman or Husky.
Old Jun 24, 2005 | 11:19 PM
jabez's Avatar
jabez
I drove my car up Berg Ramps and still couldn't fit this fat body underneath.
Old Jun 25, 2005 | 06:27 PM
Kryms3n's Avatar
Kryms3n
From: Danger..Do Not Spank this Monkey.. Happy 2015!!
Try Race Ramps.
http://www.raceramps.com
Old Jun 25, 2005 | 08:22 PM
artvette's Avatar
artvette
Take an old polishing bonnet, lay it on top of the floor jack and presto...no scratches
Old Jun 25, 2005 | 08:23 PM
mseven's Avatar
mseven
Whats the problem w/using a floor jack, is your ride a show custom, plated, epoxy painted, pinstripped , neon lighted...... then just have something on the jack plate
I guess real ramps of some sort is your only option, or a quick oilchange joint..
Old Jul 9, 2005 | 03:25 AM
yzf7r's Avatar
yzf7r
Originally Posted by CentralCoaster
I couldn't find any planks small enough to fit under mine so I just turned it upside down and set it on a soft surface so I wouldn't scratch the paint.
Good luck!
Thats the funniest sh$t i've seen in a min!!!
Old Jul 9, 2005 | 10:28 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
You can't fool Darth, Central. He can tell that's not your C4!
Larry
code5coupe
Old Jul 9, 2005 | 10:35 AM
jabez's Avatar
jabez
Originally Posted by Aquaman92
Pep boys sells Berg ramps for 19.99 15.99 on sale why bother with 2X6?
I tried using Berg Ramps. It was still hard for me to get under there.
Old Jul 9, 2005 | 10:46 AM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
Default Darth, bring the car over...
...I'll do it for ya.
Oh, Dan, wannna get in on this?
Old Jul 9, 2005 | 10:54 AM
96dblblack's Avatar
96dblblack
How about an engine lift, strap it to your front bumper and jack her up. If you can get it high enough you might be able to just stand there and do it and not worry about scraping your back.
