94 ODB trouble code reader
Old Jun 25, 2005 | 06:28 PM
grayml's Avatar
grayml
Default 94 ODB trouble code reader
Hello all,
Has anyone bought a trouble code reader for a 94 that was reasonably priced? If so, from where and how much?
Old Jun 25, 2005 | 06:29 PM
grayml's Avatar
grayml
I meant OBD not ODB.............
Old Jun 25, 2005 | 09:13 PM
RAGOVET's Avatar
RAGOVET
St. Jude Donor '05
I purchased a CP 9150 actron OBD I/II reader. It reads both OBD I & II codes so it is good for pre and post 1996 autos. I have a 1995 which has OBD I codes with the OBD II connector. The 94 would have OBD I codes and connector , so along with the CP9150 you will need the 12 pin cable Cp9127 (ALDL cable type) which comes with it. I got my 9150 from autozone for around $299. It was worth it cause it reads both OBD I and II codes so can be used for newer cars too. see www.actron.com for more details.
http://www.actron.com/product_detail.php?pid=16143
Old Jun 25, 2005 | 09:36 PM
Saisling's Avatar
Saisling
St. Jude Donor '05
I run WinALDL on my laptop and hook up to the OBD1 port with a cable I made... Do a google search for WinALDL and you'll find the software download and instructions on how to make the cable...
Old Jun 26, 2005 | 12:09 AM
Insane1's Avatar
Insane1
Are you sure it isn't and OBD II system with an OBD i connector? My daughters 94 Formula has the OBD I connector and OBD II ECM
Old Jun 26, 2005 | 11:20 AM
RAGOVET's Avatar
RAGOVET
St. Jude Donor '05
I am positive. My 95 corvette has the OBD I codes but uses an OBD II 16 pin DLC connector. However, I am told that some 95 models (GM) may also use some OBD II codes too. OBD II codes officially came out for 1996 models. I researched this online to confirm the OBD I codes with 16 pin DLC connector for my 95 corvette. If I can find the web site again where I found this info, I will append it.
I would guess that a 94 would have the 12 pin ADCL connector and OBD I codes ??
Old Jun 26, 2005 | 11:26 AM
RAGOVET's Avatar
RAGOVET
St. Jude Donor '05
Sorry , I meant ALDL connector.
try this web link http://www.troublecodes.net/GM/
see 94 5.7 L VIN P
Old Jun 26, 2005 | 02:07 PM
Saisling's Avatar
Saisling
St. Jude Donor '05
It's my understanding that both 94 and 95 Vettes have the 16 pin OBDII ALDL connector, while 83's and back are 12pin OBDI.
I've heard that there are a few OBDII codes and mostly OBDI codes from the 94's and 95's.
96 and up have the 16pin connector and are OBDII systems.
Old Jun 28, 2005 | 01:00 AM
Insane1's Avatar
Insane1
I will have to look into this further. I was told by the dealer that my daughters 94 Firebird Formula had an OBDII computer in it when I thought her computer was bad. They told me that after I installed it I would have to trailer the car to them so that they could program the computer to work.
To 94 ODB trouble code reader
