replace convertable top
Old Jun 26, 2005 | 04:34 PM
davegui's Avatar
davegui
Cruising
Default replace convertable top
Hi everyone, I just ordered a new top for my 89 convertable. Does anyone know of a website that explains how to replace the top, or does anyone have any experience in this that could lend any help or tips
Old Jun 28, 2005 | 05:37 PM
corvettemike50's Avatar
corvettemike50
8th Gear
Default cov top
just pay someone to put it on for you......
Old Jun 28, 2005 | 06:51 PM
HOOBS's Avatar
HOOBS
"WARRANTY"
Old Jun 29, 2005 | 09:40 AM
jcd89's Avatar
jcd89
Cruising
Let me know how that goes, because Ive also got an 89 convertable that needs a new top. If you have any tips on where to get it, etc, send them along as well.
Old Jun 29, 2005 | 11:54 PM
Bartmantwo's Avatar
Bartmantwo
I changed the top on my '87 vert. It is a pain in the butt. You will spend half a day stripping the weatherstrip adhesive.. Basically the top is just glued to the front bow and the rear bow. You will also need to replace the weatherstripping that the windows seal against. I spent about 10 hours over a couple days doing mine. Next time I'll just pay someone to do.
Old Jun 30, 2005 | 12:07 AM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Try here www.alknochinteriors.com
I installed a top on a C3 a few years ago using a video he provided. Maybe he makes one for the C4 also.
Corvette America lists a vinyl top for $289.
Edit: I looked at the Al Knoch on-line catalog and saw the same C4 vinyl top for $219!
Old Jun 30, 2005 | 01:26 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
I just got done putting one on my 94.
Make sure the top is in the center .
Before you remove the old one mark the center of the old front and back.
You will need all new window weather strips.
Glue the front in place first and install the back weather strip around the
drivers window first.
Take pictures of that area and screws first to make sure it is in the center of the rail.
Use a brush on glue and brush it on both sides.
After you are done don't cut off the excess in the back until the next day.
I would also replace all the felt.
I just got some industrial velcro and only used the felt part.
Old Jun 30, 2005 | 10:14 PM
fnseeker's Avatar
fnseeker
Default update to a glass window if you can.
I replaced mine two years ago. I took the frame and hung it from the ceiling and my motor hoist upside down. This kept the frame fully extended the whole time. It made lining up the top alot easier. If you can I would upgrade to a 94-96 glass window. It glues right on those old frames. A little stiff at first. You have to pull the window out over the frame as you put the top down. But once stretched out(6 months or so.) the top works great. I don't know if all tops take that long to stretch out, but mine did.
Old Jul 1, 2005 | 10:21 AM
Rick86's Avatar
Rick86
I have an install video that I purchased about 5 years ago. It walked me through pretty good. I might be able to dub you a DVD of it. (video was not copyrighted). Many people on this forum have sucessfully installed thier own tops. If you're a hands on kind of person you should have no problems with getting great results. IM me and I'll give you my phone number.
Rick
Old Jul 1, 2005 | 10:38 AM
ot180's Avatar
ot180
anyone have an estimate on how much a company would charge to do this assuming you had you own top
Old Jul 1, 2005 | 03:38 PM
Flame Red's Avatar
Flame Red
My quote was $1200 + weatherstripping.
Here is a tech tip that should help. The video is a must
https://www.corvetteforum.com/techti...=117&TopicID=2
The key is to get all - I mean all - the old glue off the back bow. That is where I ran into trouble.
Old Jul 1, 2005 | 03:44 PM
Aquaman92's Avatar
Aquaman92
Wow $1200.00 that might make me try this on my own when my car needs a new top.
Old Jul 3, 2005 | 08:24 PM
davegui's Avatar
davegui
Cruising
thanks everyone for the input.
I got it on and it looks great. It was a lot of work though, not
hard work but you must go slow and make sure everything is right.
I ran into one little problem, I clued the top and molding on the passengers side but didnt notice it was not pulled back far enough and the window pressed against it when I shut the door. I fixed it by removing the weather stripping again and repositioning the top a little further back.
It was a lot of work but I saved alot of money and am happy the
way it turned out.
My suggestion to everyone is just go slow, make sure everything is the way you want it before you glue.
Thanks again
Dave
Old Jul 11, 2005 | 10:10 PM
diyguy's Avatar
diyguy
Anyone looking for a almost new top - complete, try here
C4 Series Vert Top / Frame
To replace convertable top
