Air Conditioning Refill
Old Jun 27, 2005 | 05:26 PM
Sprongs's Avatar
Sprongs
Default Air Conditioning Refill
Need to replenish the A/C on a 93 Coupe. Plan on having the system changed from R-12 to R-134a. Was told that somewhere under the hood it tells how much refrigerant is need to fill the system. Can someone tell me where to find the info or how much is needed? I have looked every where with no luck.
Old Jun 27, 2005 | 08:43 PM
SunCr's Avatar
SunCr
GM usually puts it on the blower motor case. The '93 should take 2.25 lbs of R12 (use 80% of that for an R134 conversion or 1.8 lbs - about 2.5 12oz cans) plus 8 ozs of compatible oil (assuming you're going to swap out the accummulator - put 4ozs in the new one and 4 ozs in the compressor).
Old Jun 27, 2005 | 09:07 PM
johnnyevans's Avatar
johnnyevans
Just a little ditty for everyone.
R-134a will be outlawed, like R-12, in a couple of years.
Price has jumped from around $81 for 30 lbs to over $270 for 30 lbs.
Buy it now if you want it, R-22 too.
It was listed as an interim gas.
I think R-22 is gone in 2008 too. Hello Puron, ask Carrier.
To Air Conditioning Refill
