Wipers hitting each other
This is my first post here. I just bought a 93 Ruby 3 weeks ago. I had to use the wipers today because of the rain and they hit each other and sometimes one will stick straight out and slam back onto the windshield.
Can anyone give my any advice on this problem.
Thanks in advance for taking the time to read my post.
I noticed that the drivers side wiper arm sweeps downward ahead of the passenger side. As the pass side follows, it was here where contact was made. I slightly bent the outer end of the drivers wiper downward to prevent the contact.
Works fine now! And at highway speeds..
So where are you from? Mercy, driving a Vette in the rain in July!!!
I'd drive them back to the dealer and see what they say.
http://www.evil-one.com/~mjf/vette_wiper.htm
Hope this helps.
Rik
http://photobucket.com/albums/y126/Riks40th/
This upgrade will resolve your problem. I wouldn't put it off too long as there have been reports of the blades colliding and one pops out forward and causes damage to the hood. Then it becomes a very expensive repair instead of just an upgrade.
Note you cannot mix 96 arms with older model blades.
Also note that it is very important to put the correct blade on the correct side. They are only a fraction of an inch different but if they get reverse then they too will collide. (ask me how I know this lol).
Anyway Right and Left reference you sitting in the vehicle, therefore right is passenger side and left driver's side.
Give Chris at Superior a call 1-800-728-8267 and order the following:
L blade 22154985
R blade 22155368
L arm 10288071
R arm 10288072
You should expect to pay roughly $17 for the blades and under $16 for the arms. Those are your discounted prices from Superior.
This will fix your problem.
