I just got my build sheet that I ordered from the NCM. Now can someone decipher this thing? I can figure out several things but there are so many items listed and number codes, most of which I assume might be good if I need to replace any of these items?
The RPO codes in the botton half of the sheet describe the standard and optional equipment that went on the car. The boxes in the top half are component codes that the assembly line workers use to pull components from cartons and shelving for installation and are not option codes.
This is the info I didn't have clue about. I had already figured out the option codes and what they stood for... it was all the rest of the stuff I wasn't sure about. Thanks
I can tell you one box says FSK, and another says NYU.
Hey freak, you are correct. Those special to the Z07 package I assume? I'll have to scan it in 2 parts. I had the build order laminated and it is 11 1/4" x 13 5/8".
