smog pump
Old Jul 10, 2005 | 11:01 AM
culuknn2's Avatar
culuknn2
Default smog pump
the smog pump on my 89 is making some noise.does it suppose to make noise or is it time to go.i heard the noise its making is normal.is that true
Old Jul 10, 2005 | 12:40 PM
SunCr's Avatar
SunCr
Should be barely audible - If it's a pumping noise, suspect a leak or if it's to the right of the water pump below the switching solenoid, it's diverting air to the atmosphere instead of the cat. If it whining, the bearing is gone, though I'd make sure it's not the alternator. A reman pump shouldn't cost very much, though I haven't bought one in years - replacing mine when it turned out that the alternator was the problem - oops!
