check engine light
Old Jul 10, 2005 | 01:16 PM
takovr's Avatar
takovr
Default check engine light
I took off my MAS and now my check engine light stays on is there a way to re-set it so it dosen't stay on?
Old Jul 10, 2005 | 01:45 PM
CREWZIN's Avatar
CREWZIN
To reset it just take off the negative battery terminal for a couple minutes but it's the computer that will see that there's no signal coming from the missing MAS so it will come right back on. Don't you need the MAS to get the Vette to run right?
Old Jul 10, 2005 | 02:08 PM
takovr's Avatar
takovr
Default took it off
I took it off to fix the black hose in front of it it was cracked
I then put the Mas back on after I did that when my car is runnig the check
engine light stays on now.
To check engine light
