radiator
Old Jul 10, 2005 | 10:10 PM
jarrettjp's Avatar
jarrettjp
Default radiator
hi all! had the radiator removed and cleaned out trash and when the guy pulled the radiator he hit the condenser at rhe upper right bending the fins on about a 4 x 6 inch area. will this hurt the cooling any? i also had the thermostat replaced and a newcap installed. the 90 model car still runs hot in stopped traffic.the antifreeze will not flow from the black box where the cap is to the white recovery tank. i blew water through the line but the coolant will not go into the white tank. any advice?----thanks---jp
Old Jul 11, 2005 | 02:50 PM
mikey whipreck's Avatar
mikey whipreck
you can easily straighten the fins with a small, flat headed screwdriver.
that sounds like a pretty big area...
