[B]Need Help![/B]
Old Jul 20, 2005 | 02:48 PM
IB4TL's Avatar
IB4TL
Default [B]Need Help![/B]
My vette has been running great and all the gauges were perfect. Last night my car just wouldn't turn on after I parked it. It has the transmitter to to unlock/lock the door and when i went near the car it was already unlocked. As soon as I tried to start it, it wouldn't do anything (no roll-over, no noise) I had to leave it and go to work. The passive keyless entry was flashing and when I returned there was a clicking noise coming from the very front of the engine (either the alarm or the horn) We tried to jump it last night w/ my friends car, and it would try to turn over, but that was it. My friend thinks it may be the battery, eventhough my battery gauge was reading perfect up-until this. If it is the battery what is the easist way to remove it? I'm stuck because this is my everyday car and I really need some help. Thanks guys.
Old Jul 20, 2005 | 02:56 PM
75 Red Vert's Avatar
75 Red Vert
Guess # 1 - Loose connections on battery or corrosion on battery cables.
Old Jul 20, 2005 | 03:05 PM
bogus's Avatar
bogus
I agree. Check those out first.
Or, a bad battery.
Old Jul 20, 2005 | 03:18 PM
IB4TL's Avatar
IB4TL
Thanks for the fast reply. I'm going to go drive to the car right now and see if that will work. If it doesn't work, I think I'm going to try a new battry. Would it be easiest to remove the side louve part of the car to get to the battery?
Old Jul 20, 2005 | 03:23 PM
scofolo's Avatar
scofolo
you do have to remove the side to get the battery out. it is just a few screws holding it in place. not too difficult
Old Jul 20, 2005 | 03:35 PM
75 Red Vert
I would try removing the cruise control thingy above the battery first. You might also have to loosen the brakets holding the computer. Try that first. If still not enough room, then remove the side part.
Old Jul 20, 2005 | 03:47 PM
ZF Six's Avatar
ZF Six
My car ran great for the almost 2 years I had it and one day on my way home the voltage dropped significantly out of nowhere, I limped it home and it wouldn't start after that. I bought a new alternator and it fixed the problem after getting it checked by AutoZone. If I were you I would do the same.
Old Jul 20, 2005 | 03:51 PM
yellowlust's Avatar
yellowlust
Don't remove the cc. Much easier to remove the side panel.
Old Jul 20, 2005 | 05:54 PM
pwrful c4's Avatar
pwrful c4
this is a good guess,had same probablem ,dirty battery cables.
Old Jul 20, 2005 | 07:45 PM
IB4TL's Avatar
IB4TL
Alright so we jumped the car an I drove it about 2 miles, and it was flashing 5y5 where the speedomoter is. Then i made the mistake of turning it off to pump gas. We had to jump it again, and as I began to drire it, it died on me, so we jumped it and I drove i home about 2 more miles. I just went and bought a new Optima battery and I'm now going to go put it in, and clean the connection. Hopefully this will solve my problem. I'll let you guys know what happens.
Old Jul 21, 2005 | 03:54 AM
IB4TL's Avatar
IB4TL
I was able to change the battery, and when I checked the volts using the car gauges, it started out at 14.4V I took it for a drive and made sure to use things that would help me drain the battery so I can see if my alternator is messed up. It's currently at 14V after being at 13.9 I tried to use a voltmeter but had trouble because the markings were off. My problem is early Friday morning I have to leave to drive to Ohio and I'm worried about something happening while I'm on the road. What would you guys recommend I do? Do you think my alternator is bad, or the battery gauge is off because even minutes before the car died the gauge was reading a perfect battery.
Old Jul 21, 2005 | 09:06 AM
75 Red Vert
Why don't you stop by Advance Auto Parts or Autozone and have them check out your altenator. They do it for free. That way you will know if its your altenator or not.
Old Jul 21, 2005 | 10:18 AM
ShawnZR-1's Avatar
ShawnZR-1
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
If you were able to start the car with a jump and drive it, your alternator is very likely OK. The SYS message that you saw is very common when the battery has died.
Almost all cars will run without a battery as long as you can get it started (jump it). Just don't put a lot of load on the electrical system (headlights, A/C, 2000 watt stereo).
Also, almost all cars will run for a good while without an alternator following the same rules, very little electrical load. I mean it will run for a couple few hours or more! It's surprising how little current an engine needs to run compared to everything else in the car.
Old Jul 22, 2005 | 03:14 AM
IB4TL's Avatar
IB4TL
Hey guys, just wanted to let you know that I changed the battery and tested my alternator. All is well and the alternator I have is in good condition. Just in case any of you decide to buy an optima battery, there are two connections sticking-out the top for jumping cars. If you put it in it will touch metal underneath the radiator and c.c. which will cause more problems, so what I did was cut the positive (only one w/ interference) connection and capped it off so there can't be any problems in the future. Thanks for all your help, hopefully my trip to Cleveland will be uneventful now (I'm leaving in 3 hrs.)
To [B]Need Help![/B]
