My instrument cluster and my information center are not working.
My check enging light comes on when starting the car and goes out right away as it should. After about 15-20 minutes of driving it comes on again. I have disconnected the battery but that doesn't seem to reset it as I thought it might.
Any suggestions? Could this be a malfunction in the system, a bad sensor, etc?
Valkryder
If the light stays lite theres probably a sensor malfunction.
Take it to a shop and they can pinpoint the problem. Could be an 02 sensor. Does the mileage suffer?
i get the check engine light sometimes still,
i replaced my coolant temp sensor but the plastic connector was missing the tab that holds it on. if i really get on the gas or hit a bump it will sometimes disconnect long enough to give me the check engine light. clears up when i turn the car off.
I understand how to pull the codes, but haven't done it yet. I believe I have to short out the two end contacts, turn on the key and watch for the blinks. Is that correct?
I suggest going to Autozone. I went there and they gave me a 2 pronged metal key to short the contacts out, and also a booklet that explains the codes. I was having a similar problem, my light would come on after about 15 minutes of driving at high speeds. the code indicated O2 sensor. however this was almost a year ago and I have not changed it and have seen no ill effects.
