c-4 codes
Old Jul 28, 2005 | 07:50 PM
dallasknight's Avatar
dallasknight
Default c-4 codes
Does anyone have the codes for a 1985 c-4 with the lt-1 or know where i can find them. and how to reset the codes? thanks guys.
Old Jul 28, 2005 | 08:05 PM
CoolVette86's Avatar
CoolVette86
From: Partying with the Cowboys cheerleaders in Mt. Olive, New Jersey
First off, '85s have the L98, not the LT1 (that is, unless someone took A LOT of trouble to put one in). Here's a link to a good C4 site.
http://www.corvettebuyers.com/c4vettes/ecm.htm
By the way, a good investment would be to get yourself a Helms shop manual. It will help you diagnosis most if not all of your C4's ills. Very good read! Good luck.
Old Jul 28, 2005 | 08:18 PM
Brenda1's Avatar
Brenda1
You reset the codes by disconnecting the battery for 10 seconds. Bingo, codes reset. I have a shop book-post the codes you are pulling and I will look them up for you
Old Jul 28, 2005 | 08:30 PM
dallasknight
thanks guys i will go have the scans read tonight when i get home
Old Jul 29, 2005 | 09:04 AM
dallasknight
when i tried touching the a&b my fan came on but i did not get any of the codes just the fan came on. so what did i do wrong
Old Jul 29, 2005 | 12:34 PM
Brenda1's Avatar
Brenda1
You can also just touch the "A" to ground. When your fan came on the "service engine" light should have blinked once/twice....once/twice...once/twice (three times) Next, it will either continue doing the once/twice code for no codes stored or give you an actual code....like it blinks 4 times then 4 times....it should do this three times again....when it goes back to once/twice then there are no more codes stored. The bottom line....your were there and you didn't even know it. Good luck tonight!
Old Jul 29, 2005 | 04:28 PM
Brenda1's Avatar
Brenda1
One more thing....turn the ignition key to the ON position but do not start the car
To c-4 codes
